Question about LG Studioworks 440SI 14" CRT Monitor
LG 440SI CRT - LG Studioworks 440SI 14" CRT Monitor
    Genius:
  • 1,478 Answers
What is the problem with your monitor? i would appreciate if you can give detail information on the problem, so that i can advice on it.
Take care.
Posted on Jul 18, 2010
Have Minolta 440si. It was 'dormant' w/o battery for several years. Wanted to use. Loaded fresh battery and film. No shutter operation at all. But,display is visible and auto film load and rew
If it has been stored for so long, the internal battery, which maintains the settings etc and is charged from the main battery, is probably defunct.
May 25, 2017 | Minolta Maxxum 400si 35mm SLR Camera
Monitor is not showing the display after booting.
Hello!
Yes you have change the settings of your display to a higher resolution and your monitor is not compatible with that setting, to fix this you can bring your system unit to a friend or neighbor who has a computer and try changing it if your friends monitor is capable or compatible with your display settings. Or if you have other monitor you can swap it.
Hope I was able to help.
Jul 30, 2010 | LG Studioworks 440SI 14" CRT Monitor
LG Studioworks 440Si is slightly shaking. Can u pls. identify and tell, how crucial this problem could be?
this has to be cause it is working without the video card driver ...and when you drag or do sudden moves in leaves traces and shakes....so ...either provide the Operating system and the card name ...or if it is an on board card ...see the driver on the mother board drivers cd..
Dec 21, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
When i start up my computer it says on the monitor out of frequency
when You start the monitor please press F8 button of keyboard upto dos screen come and select a option that Enable VGA Mode and press Enter.Might be problem will resolve.login through administrator and set the display setting as 1024*768 .If again problem comes that out of frequency ,then restart the system and press F8 and Enable VGA Mode and login and re-install the Graphics driver again.If issue not resolved then problem with VGA port in CPU or VGA Cable not supporting gt it replaced.
Nov 13, 2009 | LG Studioworks 440SI 14" CRT Monitor
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Not working 1024 by 768 pixels resolution
reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
Nov 13, 2008 | LG Studioworks 440SI 14" CRT Monitor
Power supply get dropped
what power supply do you mean Sir/Ma'am.
is it the AVR (automatic voltar regulator)?
if its the AVR, just switch it on and check the output voltage with a multimeter (AC range 250)
you should see the voltage output nearly equal to your SERVICE AC voltage
Nov 06, 2008 | LG Studioworks 440SI 14" CRT Monitor
Monitor problem
Your request for the exact problem will require a signal injector and use of an oscilloscope or even more test equipment. One possible cause is the contrast set to minimum.
Sep 16, 2006 | LG Studioworks 440SI 14" CRT Monitor
LG Studioworks 440SI 14" CRT Monitor Logo
53 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
