Question about Goodman CLQ36AR49 Air Conditioner
I just had a new Goodman 13 seer installed on 6/5/10 and the unit wont turn off and doesnt seem to cool down the house had new duct installed also they changed out the fan but it runs all day without turning off and wont get cold? any help would be appreciated
    Problem Solver:
  • 10 Answers
CALL AN EXPERT......THE WIRES AT THE CONDENSER ARE NOT CONNECTED PROPERLY.THE UNIT SHOULD HAVE BEEN VACUUMED/PUMP DOWN BEFORE STARTING UP .POSSIBLE LOW ON REFRIGERANT ALSO.
Posted on Aug 08, 2010
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
Which direction should dampers be in order for the air to flow down? I bought a new house and all the hot air seems to be upstairs while it's freezing in the basement.
If you look at the end of most dampers, there is a line on the end of the shaft. this line when it is in line with the duct it is open, and when it is 90 degrees to duct it is closed. for most damper and motor, when it rotates clockwise it goes to open. and counterclockwise it shuts. default position on zone systems is open, most damper motor spring return to open. There is a allen set screw that anchors the motor to the shaft. to set up the motor and shaft, turn power off, unset set screw and rotate damper ccw and reanchor the set screw, repeat for all damper and associated motors.
Feb 13, 2014 | Goodman Manufacturing Hvac Direct R410A...
Unit wont start and error code led is blinking five times
Check the unit from the outside. This happened to me: 1.) The unit was not raised off the ground 2.) Rodents had chewed on it. Or it could be: 3.) Replace batteries 4.) The unit will not work off season when it gets too cold to use the cool air option.
Jul 10, 2013 | Goodman Manufacturing MSG12CRN1N -...
I just had 'goodman gpc1336h41ab' 13.00 seer unit installed , I have a 1250 sq. ft. home and it just doesnt seem to be cooling. The unit runs constantly. So my question is , is my unit big enough...
There are a few variables that determine the size needed to cool your home - the size of your home, type insulation, are just two. I have a 2600 sq ft home - about 1300 sq ft per floor. I choose to cool the entire second floor (bedrooms and baths) and two of the largest rooms on the first floor (kitchen & living room) via flexible ducts from an air handler installed in my attic. My house was built in 1960, and at the time had electric heat. This means it is fully insulated. I replaced all the windows with energy efficient types, and vinyl sided. I installed soffit, ridge and gable vents to keep my attic well ventilated. I can cool my house in Boston, MA to 70 degrees (when it is 85 degrees inside) with a 4 ton unit in a little over an hour with no problem (one ton of cooling is equal to about 12,000 BTUs). Your condenser should not run non-stop. If it is not cooling then it is not a thermostat problem, but could be a gas charge problem. If you haven't paid the contractor in full yet - that may be the reason why. The contractor should know how much cooling you need for the space you have and installed a properly sized unit. Make sure your air filters on the return are clean and replaced regularly. Call the contractor and explain the problem - he should be able to solve it for you very quickly.
Aug 03, 2011 | Heating & Cooling
I had a power surge on my 15 year old HVAC residential Trane Unit. I can either have my insurance repair it or I can pay the difference to replace. I do have coverage to pay for Alabama state building...
13 seer minimum for new installs. I have seen ratings as high as 18 or more on
some units (410A systems)
I recently replaced my system with a 13 seer R22 system, since they are
more easily serviced and I am very familiar with them. Given the average lifespan of
a system before major service is around 10 years depending on model.
I have worked on Trane, Carrier, Intertherm and Goodman units and prefer the Goodman
units, as they seem to be much quieter running and are built in America.
Jul 15, 2011 | Heating & Cooling
NO PROBLEM YET, JUST HAD A GOODMAN AIR CONDITIONER INSTALLED MODEL CKL36-IL AND WAS TOLD IT HAD EXCELLENT EFFICIENCY TO FIND OUT THAT ITS A 10 SEER EFFICIENCY RATING WHICH I UNDERSTAND IS THE LEAST...
10 seer was the most efficient for the older generation units and in 1992, it was required that any unit has to have 10 seer or greater. The least efficient seer rating you will find on any new unit will be 13 seer which is a lot better than 10 seer and will save you almost 30% in energy cost. As of lately, they have made units available that are up to 20 seer or more, but they are pricey. I know you said you just had the unit installed, but from the model number, I'm assuming it is an older unit? If new, then it would have at least a 13 seer rating. Hope this answers your questions!
Aug 18, 2010 | Heating & Cooling
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
I can't seem to get my pressures up on a new 3 ton 13 seer goodman? High side 200psi low 50psi not cooling the house
You might have a bad valve on compressor.Close valve on high side and see if the low side pumps down. Of course you should have your gages hooked up.If your low side doesn't pump down you have a bad valve.
Jul 10, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
123 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
