Question about Toshiba 42HM66 42" Projection HDTV
Tv unexpectedly powers off
1 yr old TV - approx 6 months ago the TV would power itself off. It was a rare occasion. We changed the lamp and it was ok for several months and now the issue is back again and even worse. It powers itself down after several hours of use. takes several minutes before it can be turned on again and will stay on for maybe 30 minutes or less before the dance begin agains.
  • 2 more comments
  • Linda Bernadyn
    Linda Bernadyn Apr 24, 2008
    i have the same problem. Sears can`t figure the problem out. replaced 3 bulbs and the ballast. now they are going to replace the power unit hope it works.
  • Anonymous May 16, 2008
    I'm having the same problem...the tv works fine for a couple of hours then it just turns itself off. And after the initial power cycle, it continues to power itself down approx every 15-20 minutes. It take a few minutes to completly power down before you can turn the power back on.. It has been a seriously annoying problem and I am considering purchasing a new TV.
  • mrsbenny May 17, 2008
  • zmitchA Dec 20, 2008
    toshiba 42hm4266 same problem but the tv will not come back on it just go through it codes check that all. I have change the light but it still doing the same thing.need the schematic for this model,to find out what wrong.
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Posted on Jun 08, 2008
Hi, i suggest to you just un plug your tv... and open the little pannel in the right side of you tv....(Not the side of the lamps, otherside!!) and clean and remove the dust overload on the little hole
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
I have a 6 yr old Mitsubishi DLP WD-52327 does not fire up... When power is turned on tv makes a noise like a small air compressor for a few seconds and then stops after about 1 minute it does it...
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
Oct 23, 2010 | Televison & Video
My 42 inch Sharp 1080p will not power up. It's only 6 months old, and a month ago it just powered off, and won't turn back on. Any suggestions...I thought maybe my grand children did something with the...
Check the power source?Try unplug,replug tv an hour later.Let the tv resetting itself back to factory setting.The tv should work now.No,LCD tv have common problems power supply board died alot.This tv is new,call Sharp for warrenty repair.
Sep 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv will not power on
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hope this will help...
May 28, 2010 | Element Electronics 26 in. LCD TV
My toshiba 50HN67 TV won't power on.
can u tell how much times the light blinks..
then i can give solution...
thank u,,,///please rate it
Jul 02, 2009 | Toshiba 50HM67 50" HDTV
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Hitachi 50VF820 (LCD projection)randomly turns off, all three lights (temp,lamp,power)blink then the set turns back on after approx. 30-45 seconds. Lamp was changed approx. 4-5 months ago. Cleaned out all...
I believe I may have solved this problem by putting a small fan blowing on the intake of the Lamp fan. I put the fan in place and the TV has not turned off randomly since. That was only a day ago so I'll see if it is a permanent fix. If so I will probably try to mount the fan on the back of the TV out of sight.
Jul 16, 2008 | Televison & Video
Toshiba 42HM66 42" Projection HDTV Logo
254 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
