Question about Sirius SUBX1 Universal Plug and Play Boom Box Boombox
I am getting no antena found on my subx1. I have used 2 different antenas that I know are good
  • 532 Answers
The issue with antenna not being detected is in the female contact of the antenna's plug, not with the connector in the box (as I expected to find). I have not yet verified this by trying a new antenna. Here is how to dissassemble the box in any case.
Very carefully, with a small very flat screwdriver, remove the front grille of the unit. There are 8 additional screws set in deep holes that need to be removed. Once done, the front panel will pop right off.
The inside of the case is a mess of wires. You do not need to disconnect them if you do not want to.
Pry the grill off the bottom of the box. Remove the 4 screws that hold in the speaker. This will allow you to move the speaker that is in the main body out of the way.
The antenna jack is _not_ a part of the circuit board. If you look into the box, you will see a rectangular cut-out in the edge of the circuit board. There is a wire with a silver connector that is held in place by 2 screws. Remove those screws and you are now holding the antenna jack.
Thanks for contacting Fixya.
Posted on Jul 18, 2010
  • tfoster1283 Jul 18, 2010
    What can I do with the female contact on the antenna's plug to make it work again. It seats in fine. Is there any way of cleaning the contacts????
I would like to know if this model PHd8000 is still available for purchase
Hello, Kimberly -
Clarification: Are you asking about a digital high definition (HD) television antenna made by Prime Tech?
If so, the answer will depend upon where (what country) you reside. So far, I have only found the antenna sold through Brazil based websites.
In case you reside in Brazil, see:
https://www.zoom.com.br/antena/antena-de-tv-externa-prime-tech-phd-8000
and
https://www.extra.com.br/tvseacessorios/acessoriosparatvs/AntenaseReceptoresparatvs/antena-digital-externa-prime-tech-uhf-phd-8000-suporte-para-antena-de-aluminio-phd-8000-sua-9289711.html
and
https://www.pontofrio.com.br/tvseacessorios/acessoriosparatvs/antenasereceptoresparatvs/antena-digital-externa-uhf-phd-8000-phd-8000-9124021.html
Best wishes.
Jun 19, 2018 | Televison & Video
MY EMERSON RADIO MODEL RP6251 ANTENA BROKE. I NEED ONE
Hello
The telescopic antena can bw bought from most of the electronic spare part selling shops at your town. You have to take your borken antenna with you to show them as sample. There are many types of base fittings to the telescopic antena. So you have to open your radio, and unscrew out the base of the antenna also to select a new one. See the different types of seating bases to antenas.gopakumarg43_87.jpggopakumarg43_88.jpg
Oct 13, 2011 | Emerson RP6250 AM/FM/Weather/TV Radio
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
My sirius satellite radio stopped working antenae not found
my sirius satellite radio stopped working the screen states antenae not found in the car and at home on the boom box the antenae has been checked and is not the problem can this be fixed ?
Jan 29, 2010 | Sirius Satellite Radio Audio Players &...
My tv has a different tv out where the antena is connected. Antena tv has a kind of like a screw at one end and at the other end is the antena. All tv has the right connection for the antena but my daewoo...
it sounds like either:
-the tv was intended for a foreign market.
-the tv does not have a tuner (it is just a monitor)
the connector on the antenna is an "f" connector.
if the connectors on the tv are "rca" then it is probably just a monitor - and needs an external tuner (ie dedicated tuner, cable box, tivo, vcr, etc)
if the connector on the tv is a "bnc" then the tv may be meant for the european market, and probably can not tune channels in the us.
see wikipedia.org for images of bnc and rca connectors.
you can certainly get an adapter from/to any of those connector types, but i think that alone is unlikely that will solve the problem. check or find the manual for the tv - be sure it actually has a tuner compatible with the signals you want to receive..
Oct 21, 2009 | Daewoo Televison & Video
My Vizio VW 26L loses all the digital channels when it is turned off. It works fine after a channel scan, but when it is off then back on there are only analog channel available. Bad tuner?
Tries different antena like a roof antena,or digital antena get better amplication input for receptions,still have signal not ur DTV tuner.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
1985 ZX300 power antena problem. When the radio is turned on the antena goes down and when it is shut off the antena goes up. Al factory parts, radio, antena and all switches. Any ideas what would cause...
im guessing the antenna has been replaced and wires were mixed up. take the rear panel off in the trunk to give access to the antenna motor and look at the wiring there should be 2 small wires and one larger black wire. the black wire is the reception wire the other two are the power wires. switch the positions on the two power wires. say wire A is in plug 1 and wire B is in plug 2. final position should be A in 2 and B in 1. that should take care of it. good luck
Jul 08, 2009 | 1985 Nissan 300ZX
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Can i use existing satelite antena on my audi
The antenna should plug into the Stilleto car kit if your Audi is equipped with Sirius already. Otherwise you will have to use another Sirius antenna.
Mar 07, 2009 | Sirius Satellite Radio Receiver
Sirius SUBX1 Universal Plug and Play Boom Box Boombox Logo
69 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
