Question about Kenwood Audio Players & Recorders
I hook up my speakers but have very little sound why
  • Kenwood Master
  • 17,130 Answers
First of all take an AA 1.5 cell and use it to test the speakers you are using. If there is good movement of the coils identical to both sides , we can proceed further. Now open the power amplifier and check within the output side where all the mosfets are mounted. Check for the +B( the main Voltage) in both the L&R sections of the amplifier. Now use a good signal tester or even you can use a line output audio with a serious capacitor ( about 2.2 mf) to check stages in ascending order from the output stages. Test at all the couplings to confirm the gain of the amplifier. The fault could be failure in the preamplifier or the source selector. Try to check all the inputs , if there is better output in any other source input, in such a case use this till you can get help to change the preamp selector. hope this helps. Good day
Posted on Jul 19, 2010
I can not get the sound to work on the tv without the speakers
Need to know some things:
Brand and model number of the set.
If you connected speakers from one unit to another did you disconnect speakers from the TV?
Speakers have different impedence's---(resistance) and if you hooked for example a 32 ohm to a set which uses 4 ohm speakers you may have little or NO sound.
Also if for some reason you had both speakers for both hooked up at the same time and turned the units on---may have destroyed the audio circuit.
Clarify a little what is hooked up and from where and how.
Mar 24, 2012 | Televison & Video
Hooked to speakers. no sound do i need a reciever? and if so what kind.
Yes, unless you're using self-powered speakers. Then there's the little matter of controlling volume. Otherwise, any amp or receiver that accepts the RCA or digital outputs. Find and read the manual.
BTW: how did you hook it to speakers?
Jun 13, 2011 | Pioneer PD-F407 25-Disc CD Changer
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
I have my Sony Bluray hooked up through the AVR-1804 and when the sound is a little loud the receiver just shuts off. Doesn't happen with the DVD s played on the same player but when I actually play a...
Sounds like the protection circuit is activating to protect the output amplifiers. Common causes are hooking up more speakers than are suggested. The only thing I can relate to only BluRay disks could be the sound is more demanding. That would not normally occur. Try lowering the volume and see if that helps. Especially don't hook up extra speakers because that overloads the unit.
Mar 30, 2010 | Denon AVR-1804 Receiver
I am having problems getting optimum sound out of my back speakers????why? there is sound but very little????i have 85 watt (2) in back of room can u suggest how to get optimum sound from back...
Define optimum.
If it tests out in the speaker setup then it's probably just fine. There usually isn't much program material directed to that speaker.
Mar 19, 2010 | JVC RX-6042 Receiver
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
No Sound Now on Computer
Might be trivial, but try the volume controls, that little speaker icon on the Windows task bar.
Dec 28, 2007 | Acer Aspire™ T180 PC Desktop
Low sound from speakers.........polk audio speaker
Hello Minikish
well, some DELL models, have an internal audio, and it is cheap sound card, others have problems with this sound cards, and must be replace. or if you want to buy a PCI X-FI from creative, really Rocks the sound to a new level 5.1 surround sound, up to 7.1
Dec 06, 2007 | Audio Players & Recorders
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
