Question about Amana ACE245R Air Conditioner
E1 error code how to reset - Amana ACE245R Air Conditioner
  • 2,133 Answers
Replace indoor room temp sensor. And then re start unit.
Posted on Jan 01, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
    highly annoying issue error code E1. After hours
    of fan operation, the error code E1 will appear on the seven segment
    LED temperature display. This error code is intended as a reminder for
    the user to clean the air filter. However, because the procedure
    outlined in the user manual does not clear this error code as
    indicated, and the appliance has a nonvolatile memory that cannot be
    reset by simply unplugging it, the user of the appliance will become
    mightily frustrated, standing in potentially sweltering heat watching
    the appliance repeatedly shut down in the midst of operation with the
    "E1" display flashing.
    Believe it or not, that is what it does: if you unplug it to remove the
    "E1" code from the display, and plug it back in and re-start it, it
    will simply run for anywhere from a few minutes to a few hours, and
    then merrily shut down again with the same flashing "E1" code.
    So you will come home to a hot bedroom, living room, etc. unexpectedly,
    and you will NOT be amused, as I was not.
    Many people at this point, having put the manual under the canary or
    some such, will simply return the unit and never buy another Sharp air
    conditioner. But for the tech-savvy and search-adept, I offer the
    following procedure to clear the nefarious E1 indication, and obtain
    1. Power down the air conditioner using the "power" button on the front
    panel.
    2. Unplug the air conditioner from the wall socket.
    3. Hold the front panel "power" button down and plug the air
    conditioner in. Continue to hold the power button down as the machine
    goes through a brief test sequence (fan & compressor each come on
    briefly, etc). There is a "beep" sound at the end of the test sequence,
    and the machine will be off. At this point, you can release the power
    button.
    4. Unplug the air conditioner.
    5. Plug the air conditioner back in.
    6. Congratulations! You should now be able to operate the air
    conditioner normally for another 720 hours, but only if you followed
    the instructions above EXACTLY.
    _____________________________________________________
    Was this solution helpful? Show your Appreciation by rating it.
    Thanks for using fixya support..You have a wonderful day
    Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    4 Digit Failure Codes
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    Tip
    F5 - E0 Door Switch
    Two digit codes:
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    How do I clear the fault codes ?
    How To Fix Maytag Washer Error Code F9 E1 ...
    www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
    Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
    KitchenAid f09 error code Dishwashers Questions ... - Fixya
    Nov 29, 2015 | Dishwashers
    E1 error code LFWC38F6LS
    Good Morning Chris,
    I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
    Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
    I have a fitness Edge 491 Recumbent bike that the display window reads E1 . the resistance is hard and I am unable to reset. when I press start stop for 2 seconds it all looks like it will reset but then...
    The bike is no longer sold and the company went bankrupt in 2014, so neither support nor parts are available from the company. Try the results of this Google search regarding the E1 error code:
    fitness quest edge 491 e1 error Google Search
    I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
    Nov 25, 2017 | Cycling
    Pioneer error codes
    E1 Error is an electrical failure. Check all Circuit breakers and insure that voltage is correct. Could be a simple wiring problem.
    It may also be possible the circuit board is damaged. Check for a reset button on the wall plug if there is one, try reseting it.
    Jun 30, 2013 | Heating & Cooling
    Samsung AQV12m e1 error code
    Check the wiring. If it's okay, reset by switching the power from the outside unit off for approx. 1 minute.
    Sep 11, 2009 | Heating & Cooling
    SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
    Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
    Aug 06, 2009 | Sharp AR-275 Copier
    Amana ACE245R Air Conditioner Logo
    450 people viewed this question
    Top Amana Heating & Cooling Experts
    Bill Long
    Pete Norton
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
