Unable to interpret connecting instructions for line in recording on dvd/vcr player, have digital cable box.
I have a proton dvd 800 and a "dish" dvr and Sanyo tv and I don't know how to hook up the dvd.
Posted on Jan 03, 2009
Ok, i want to hook up a vcr/dvd player to my tv/cable box, i want to make tapes of programs i am unable to watch at the time of airing. my tv is a slyvania LD200SL8 LCD WITH built in dvd player. my...
A VCR / DVD player is not a recorder. If it is a recorder you need to advise what input and output ports you have on each of the devices that you wish to connect, then the connection would be from the cable box thro' the recorder and into the TV.
Nov 22, 2017 | Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Magnavox DVD/VCR Dual
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Hook-up strategy
OK I will try to explain this...You need to go from your OUT TO TV output on your cable box and split that line so you have 2 lines coming out,then you can hook one to your vcr and one directly to your tv.Then you can watch tv while you are recording something on your VCR.I hope this helps
Sep 24, 2007 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
