Question about Ruud Handle Air Conditioner
How do you disconnect a heating element on a ruud air handler?
  • cntrolwiz Jul 19, 2010
    Are you talking about the heating element theat is wrapped around the compressor?
    Problem Solver:
  • 9 Answers
I guess this site has'nt been used in a long time. maybe someone can show a site that is up to date and easy to respond to.
Posted on Jan 15, 2012
the dr
  • 447 Answers
SOURCE: FINDING A DIAGRAM FOR A RUUD AIR HANDLER ON LINE
I dont have axcess to a wiring diagram but i am pretty familiar i know the heater wiring is crazy on these what are you having trouble with??
Posted on Nov 24, 2007
dcp2
  • 63 Answers
SOURCE: Wiring connection for a Ruud air handler & seeking its wiring diagram.
The orange wire coming out of the outside unit is for the reversing valve( controls the heat and cool mode of the ac) If its unhooked, it will be either in the ac mode all the time or the heating mode all the time depending on the style of the reversing valve. The orange wire goes to the (O terminal) inside the outside unit.
There is also another orange wire that goes from the air handler to the thermostat. One orange for the thermostat, and another to the condenser( out side unit)
Posted on Jan 26, 2008
  • 20 Answers
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Posted on Mar 21, 2009
james3751
  • 614 Answers
SOURCE: What is the tonnage of a ruud UHQA 1010B air
1.5 to 2.0 tons
Posted on Jul 21, 2009
Blowing fuses when set to heat
one of the elements is grounded or wires shorting.
Sep 14, 2015 | Ruud Handler Air Conditioner
Central heat not warm
either that, thermostat,sequenser, orfusible link on elements.
Jan 23, 2014 | Ruud Handler Air Conditioner
I have a Ruud air handler and i'm trying to use a
The 44360 tstat can be used for single stage Heat pump use only. Unless you are in an environment that has greater than 40 degF outdoor temperatures year-round, you will want to return that tstat and obtain a multi-stage Heat Pump tstat. The standard system is 2-stage......1st stage is Heat Pump Compressor and 2nd stage is the backup electric heat.
Hope this helps. Good Luck. :-)
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42710.pdf?n=149
Feb 21, 2010 | Heating & Cooling
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
Themostat problem no power
Your R terminal in your air-handler is the 24v power that goes to the tstat. Look at the air-handler and match the color wire. ALL tstats have a power wire going to them. If you aren't getting power, you probably have a break somewhere in the wiring close to the thermostat you are replacing.
Apr 07, 2009 | Ruud UBHC Air Conditioner
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
