Question about Dell Studio 1537 Laptop
All teh sound comming out of the machine even while starting up sounds robotic. What can i do?
  • 75 Answers
You can update the sound drive. uninstall sound driver first from add and remove programs and install the drivers for the sound card from this website http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=STUDIO1537&os=WLH&osl=en&catid=&impid=
make sure you select the right operating system you have.
Posted on Jul 21, 2010
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
SVE1112M1E headphone problem
When your PC plays music or video, what type of sound output do you get; normal or robotic?
If its normal, you may have to test/try out another headphones and connect/plug in to your PC and listen once again to the output sound.
Is it same as your previous headphones is; sounding robotic or is it normal?
Normal sound output in the new headphones (not your previous headphone), you know the answer.
Robotic sound output with the second headphones? You mahave to reload the drivers if this'd help.
However, simply hope problem is not with your PC's sound jack
Oct 17, 2017 | Computers & Internet
Someone gave me this pc and i cleaned it like a new hard drive.i lost sound,what sound card do i use and where do i download it from.thanks
my advise would be to try the update device driver, from the control panel.
Strip machine and get teh make and model number from the MotherBoard - then google for the drivers.
http://www.driverguide.com/ is a good place to start for the drivers.
Aug 06, 2010 | E-Machines etower 633ids PC Desktop
The washer doesn't drain. And even if I hit the cold water button teh water still comes out hot.
Sounds like 2 different problems going on there.check that the cold water is on.replace the cold valve..The pump is more than likely blocked or needs replacing.
May 31, 2010 | Washing Machines
The printer was printing several pages, then stopped, made a humming sound. I recieved teh error 13, and had to remove a sheet from the rear of the printer. Now when i hit the online button, there is a...
It sounds like the fuser gears are broken, that happens with paper jam sometimes from all the heat of the fuser. A new fuser will probably run around $100.00 for that machine.
Jul 14, 2009 | HP LaserJet 4p Printer
GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Mar 07, 2009 | GE WJRR4170E Top Load Washer
Lock light doesn't go on, won't fill, metal rubbing sound
thins sounds like a bad control board and wax motor issue, comon for this machine prbably about $300 for you to repair ,closer to $500 for aservice co. however, you say oyou hear a metal on metal rubbing thisi a sign of a more serious problem of rear bearing NOt worth cost of repair.. one way to tell the rear bearing is to open the washer door and grab the inner basket, try to lift it up you should have no movement iff correct. ifyour able to lift teh inner tuban inch or so, independently of the machine, i would venture to say oyou need a rear bearing// i mean new machine!!!!
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Internal speakers - no sound
hii ther
how r u???
this model is not VERY compatable with vista even acer company say it is :D
but u can go to acer.com and see the teh latest update on ur driver for vista
don't just update the driver from teh windows wizerd update
u take care and havefun
salammmmmmmm {bye in arabic}
Nov 17, 2008 | Acer Aspire 5100 Notebook
I have a problem with my sound
have you installed the correct driver? , because Vista uses Realtek HD Audio and XP uses Standard Realtek Audio, also right click on the speaker icon>audio properties and make sure that speaker volume is set to the correct speakers and not headphones or somethong else
Aug 09, 2008 | Acer Aspire 5520-5908 Notebook
Dell Studio 1537 Laptop Logo
57 people viewed this question
Alun Cox
