Question about HP PSC 1315 All-In-One InkJet Printer
All lights are steady on and the printer won't do anything
    Problem Solver:
  • 11 Answers
Step One: Document for troubleshooting steps. Please refer the below mentioned web link for the troubleshooting steps. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01578337 Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address. Step Two: Download and install a patch for Print cartridge utility. 1. Go to the link mentioned below. 2. Click on the button ?Download only.? 3. Save the file on your desktop. 4. Double click on the file and follow the on screen instruction to install and fix the error. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-16009-3&lc=en&dlc=en&cc=us&product=374568&os=228&lang=en Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address. Step Three: Semifull Reset. A semi-full reset will do the following: The user settings to the factory defaults, Language and country settings on some models Reset the All-in-One to the factory default settings by using these instructions: 1. Disconnect and then reconnect the power cord. 2. When the lights begin to flash, press and hold ON/Resume and Number of Copies. When only the ON/Resume light is flashing, release the buttons. When the ON/Resume light is steady, the reset is complete.
Posted on Jul 18, 2010
The toner and the exclamation lights are steady and i just replaced the toner for thos one E260A11A AND IT DOESN'T PRINT ANYTHING not even the test page please help need to print inmediatly
Press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the newly installed toner cartridge if it is the one suitable for your region.
For further assistance, please call Lexmark Technical Support.
Jun 23, 2011 | Lexmark E260dn Laser Printer
I just purchased my playstation 3. I can't get the Sony dualshock 3 to work. When I plug it in all the lights on the back are blinking but the controller won't to anything
after you plug in the controller, wait till the light under the 1 becomes steady and all other lights stop blinking. once that has happened your controller should be synced with your console. if this does not happen after waiting several minutes, then you have a faulty controller and i suggest to turn it back in. please rate my solution, good or bad.
May 21, 2011 | Sony Dual Shock 3 Controller for...
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
Steady yellow light on toner
May be problem on mother board or toner unite.
If it self change toner .
Feb 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a steady yellow toner cartridge light.
Jul 10, 2009 | Lexmark E232 Laser Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
All Lights are on Steady!!
Did you check the back to see if there is a paper stuck. If nothing is stuck then shut it off and restart it. I have lots of luck with this printer. I work at 2 schools and have 62 of these to keep in working order. I have only had 1 that had to be sent in for repairs.
Oct 23, 2006 | Brother HL-2040 Laser Printer
HP PSC 1315 All-In-One InkJet Printer Logo
213 people viewed this question
Ben Johnson
