My brother printer MFC-5840CN refuses to acknowledge that all ink is filled and refuses to print, even in black when I have just installed a brand new ink
    Genius:
  • 3,422 Answers
HI,
Did you try uninstalling the drivers and then reinstalling it?
I believe this will fix your problem.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 21, 2008
    Genius:
  • 3,587 Answers
Did you clean the print heads...???
The black will not print. I have replaced the cartridge with two new ones. Color prints ok. Brother mfc 5840cn
please perform head cleaning to see if there is any ink out.. goto ink management and select head cleaning... after that goto ink management and print the nozzle check.. see if there is any black ink out...if no ink out..then more probably your print head is badly clogged..and you will need to get it replaced.
Jun 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
MY MF210C IS ASKING FOR YELLOW INK. I AM ONLY
Your printer mixes colors even with black, you must have ink in all carts.
Aug 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 5840CN - no print
you need to go to brother.com for the solution
Jan 08, 2009 | Brother MFC-5840CN All-In-One InkJet...
Mfc-5840cn it wont print black and white pages, i have no colour ink but do have black ink. how do i fix?
Some printers REQUIRE a color cartidge to work, even if you're not using color.
Check your documentation to see if this is the case,
Also check in your printers' "Control Panel" or it's software to see if you FORCE black printing only.
Dec 02, 2008 | Brother Office Equipment & Supplies
Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
MFC-5840CN "unable to clean" and "machine code 50"
you have to fix the encoder strip into right position within the ph carrier! do push the head left/right to see if there are waves infront of it. if so, fix the strip into position!
BTW:
If you refill your carts use 2ml glycerol (from drugstore) with 10ml dye-ink: mix well before refilling. For bk use 1,5ml glycerol with 20ml bk dye-ink.
The glycerol prefents the ph/nozzels and tubesystem from drying up!
Apr 21, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
48 people viewed this question
jasbo
jasbo
