Kobra 240 paper shredder
My shredder keeps on running after the paper has gone through. Is there a simple solution
    Problem Solver:
  • 7 Answers
I had one similar to this i took the cover off and cleaned the sensors in the electronic eyes also there are two relays on the main board that get hung up just tap them. i cleaned real good the machine seemed to work ok after that
Posted on May 04, 2009
My shredder is not shredding.
quite likely the gears have stripped off as most are plastic .
May 18, 2015 | Intimus Kobra 240 S4 Strip Cut Shredder
My kobra shredder won' shred when we put paper in lights are on
Is the discharge at the bottom where the shredded paper comes out clear? If its blocked by paper etc, it will not shredd.
Aug 19, 2014 | Office Equipment & Supplies
Our shredder is a Kobra 240 ss5. It will turn backward but not forward. The circuit board has a burn on it. Can I order a new circuit board for it?
By now you mave resolved your prob however.... yes you can order replacement PCB's.
The part # is 27.045
Before you just replace the "blown" pcb you should also check the motor; or, when you install the new pcb you will just blow the new pcb also.( if the motor is faulty.)
To check the motor you will need a multi meter.
There are 3 wires...black, red & blue wires. Using black as the common wire measure black to red..this should be approx 6 ohms, the same when you measure black to blue. Between blue and red you should get about 12 ohms. If you get a short on any of these readings then the motor will have to be replaced BEFORE YOU REPLACE THE PCB.
You don't say what country you are in..these readings and the part number are good for the USA &Canada.
The part # will be different if you have the 240 ss5 E/S model.( has a blue light on the panel.)
Hope this helps.
Apr 05, 2011 | Elcoman 240 SS5 Shredder
Does it make a difference which shredder oil I use? There are so many. I have a Tech Solutions cross cut TS8000.
You can use any kind of shredder oil. They are all priced so differently, I use fellows brand for my royal shredder & it works just fine.
Feb 07, 2011 | Fellowes WilsonJones Q4 Paper Shredder Oil...
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
Kobra 240SS5 shredder. Reverse but no forward.
Prob;em will either be the "eyes" (try cleaning them) if that dosn't work they may need replacing OR it could be a defective pcb inside.
Nov 19, 2010 | Elcoman Kobra 400WB Shredder
Paper getting stuck once shredded
As a test try shredding into a small box or even the cabinet itself with the bag holder and bag removed. Just to see if these are causing the problem.
The bag Full switch is activated by an arm which is pushed up by the pressure of the shredded paper in the bag as it fills.
When a sheet of paper is shredded, after the trail end of the paper goes past the "eyes" the machine should still continue to run on for a few seconds to drive the shredded paper out.
May 13, 2010 | Elcoman Kobra 300 SS4 Shredder
CUTTER GEAR BROKEN
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Dahle Kobra 385SS4 Shredder
224 people viewed this question
k24674
jasbo
jasbo
