Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
Where does my green wire (ground) connect to?
  • 990 Answers
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
Posted on Jul 19, 2010
Wiring diagram
see side of motor for wiring
May 29, 2013 | Hayward Pool & Spa
How to install a power cord to a Hayward 1hp Power Flo Matrix pump.
One line lead wire to the L1 terminal, the other line lead wire to the L2 terminal and the green ground wire to the green grounded screw above the motor terminal board. It does not matter which wire, white or black, is on which terminal, L1 or L2, so long as one wire is on each terminal.
John
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
2nd Hayward Max Flo 2 hp pool pump stopped working again!!!
More than the motor it is probally a bad seal causing the problem with the motor. All you can do is be sure it is installed right when you put the new one in and if you see water under the pump take it apart and install a new one. I live in AZ and the water will evaporate before it gets to the ground under the pump so here this can be a real annoying problem. We quite often will have to look for calcium left behind when something leaks.
Jun 24, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Three pvc pipes coming into an max i flo pool pump should all three valves be open to run the pump?
Here is a link for the users manual for these pool pumps. You should be able to not only see a diagram, but also read all about which valves should be open and which closed.
http://www.backyardcitypools.com/images/hayward/power-flo-manual.pdf
Jun 19, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Sep 15, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
1,513 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
