Question about Coby TF-TV3217 32 in. LCD TV
It's showing 'NO SIGNAL' and won't respond to the remote control nor the Cable and VCR cables connected to it
  • eno247 Jul 20, 2010
    Your solution was concise, straight to the point and extremely professional and shows that you have in-depth expertise on the subject matter. Well done!
  • Coby Master
  • 11,800 Answers
I'm assuming that you have tried to change the source of the signal using the Mode button from the case and nothing happened. In that case the control processor has failed. Since it can't be replaced on its own the entire mainboard must be replaced. This will be expensive and a job for a pro - take the tv to a dealer or an authorized repair shop.
Posted on Jul 18, 2010
JVC HR-S29002U - How do I get the VCR to respond to the remote control?
i think that the time has to be set before you can proceed
Aug 29, 2014 | Televison & Video
How do you connect a VCR and a Cable Box to a DAEWOO TV that only has one Cable (ANT) connectionn on the back?
The antenna is normally connect to the VCR, which should have ant. IN, and OUT which goes to the TV. If the TV has HDMI input you would connect the cable box that way. You can also get a TV signal switch box, 2 in, 1 out, with a remote to switch it with.
May 30, 2014 | RCA Televison & Video
How do I make the remote control work on my TV. Its an old Phillips and I can't seem to connect the one for all remote to allow my TV to work
Hi! Try these steps I hope it helps..
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
The codes for your tv are:
006,007,010,011,013,016
027,033,035,043,066,087,089
Jun 10, 2010 | One For All URC3110 Remote Control
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
Mar 16, 2009 | RCA Universal Remote Control
Hi my name is Christy I need the codes for my remote control model rcr311w r55n7 4747p,how to program the remote to my sonya tv? HELPPPPPP
If you mean Sony .. its 002
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jan 07, 2009 | RCA RCR311B Remote Control
Need code
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number
Panasonic 012,013,038,086
or you can do this:
1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
electech
Nov 26, 2008 | RCA Universal Remote 3 Device Remote...
Remote control codes
RCA Universal Remote Control Programming Codes
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
000,005,007,008,028
035,037,054,069
Nov 04, 2008 | RCA VR557 VHS VCR
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
  • TV-000
  • VCR-000
  • Cable Box-000
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Coby TF-TV3217 32 in. LCD TV Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
