Rank: Guru
Rating: 89%, 134 votes
Unfortunately, the ERR99 code is a catch-all code that means an UNKNOWN
error has occurred. Because of this, it is going to be very difficult
to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For
starters, I would make sure that the lens electrical contacts are clean
and the lens is mounted correctly and fully locked home. If you have a
spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If
none of these solve the problem, the only option left is to return the
camera to Canon for a warranty repair, however if it is brand new, I
would take it back to the store for an exchange.
Hope this helps,
Matt
