Question about Sony Handycam DCR-TRV480 Digital Camcorder
My Gateway computer doesn't recognize my Sony
My Gateway (Vista) computer doesn't recognize my Sony DCR-HC52. My Gateway doesn't have a firewire port, so I bought a Dynex firewire 800 Express Card Adapter. Using the adapter and firewire, my Canon camcorder works fine, but the Sony doesn't. Unfortunately, my Canon is broke so I can't use it to load my film. Sony claims the needed drivers are already included with Vista. MicroSoft says it's a Sony issue. Is it Vista, is it Gateway, is it Sony?
I have tried with camera running in play mode, off, record mode. Still nothing. I don't know what else to do.
  • 10,421 Answers
Lost cable to the computer for the DCR-HC52
Well you could use another cable that you can buy from Electronic shops and it's called the i-link cable or 1394 or Firewire. You have to buy the more durable ones which are more expensive as these work better.
Aug 27, 2011 | Sony DCR-HC52 Mini DV Camcorder
What do I need to hookup my dcr-hc52 to my HP computer, running windows 7. My camera did not come with software to install anything on the computer. I have a cord with Dv in end and USB end on the...
Windows 7 does not support USB streaming for that camera (unfortunately). You will need to purchase an i-link (or firewire) cable to transfer video from your camcorder to you computer. NOTE: Be prepared to buy a firewire adapter for your computer (unless your PC already has a firewire input). You should be able to purchase both the cable (approx. $38.00) and the adapter (approx. $10.00) from your local "big box" electronics store.
I hope this solves your issue.. :)
Jun 05, 2011 | Sony DCR-HC52 Mini DV Camcorder
How to connect my dv via usb
The USB connection will only download still images from the camcorder. You need a firewire cable and card in your computer to download video. If your computer has a firewire port already, you just need the cable. Hope this helps =]
Feb 28, 2011 | Sony DCR-HC52 Mini DV Camcorder
Sir I have digital video camera recorder DCR-TRV265E pal. How can i Download my saved video on my labtop my window is vista . i need a softwear or driver
http://www.sony.co.uk/product/sdh-digital-8/dcr-trv265e
This model seem to have Firewire Port built in.
Then the solution is simple-use Firewire cable to capture video into your laptop.This is the standard hardware set recognized by any OS and most Video Editing software.Simply plug in your cam to your computer via the cable.Your laptop should immediately "see" your cam.The rest is then easy.
Oops...forgot to ask the make&model of your laptop.If it does not have that firewire port built-in.Then you've got quite a trouble...
Jul 04, 2010 | E.Digital Sony DCR-TRV265E camcorder Pal
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
Imac 9pin firewire port does not recognize my Sony DCR-HC52
Perhaps a USB to Firewire dongle will help sort you out. As you have discovered those two are not compatible. To make it work, you MUST get a 4 pin card and install it, or the USB solution.
Mar 14, 2010 | Video Cameras
Is there any firewire port IEEE 1394 (FireWire/i.LINK)in sony hc dcr 52e
Yes, DCR-HC52E has IEEE 1394 port, it would be labled as iLink or DV
Check left to power jack.
Thanks.
Nov 25, 2009 | Sony DCR-HC52 Mini DV Camcorder
I want to download from sony handcam dcr-140
I have same camera and computer. I use IEEE1394 FireWire(CardBus PCcard). It works for Ulead DVD MovieWriter which is in my Vista.
Oct 25, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Connect Sony Handycam to Gateway laptop
tell me the model of ur gateway laptop if u have firewire port 1394 on ur laptop u can easily connect thru cable u have to buy it separately u can go for generic one no need for an expensive branded one just check the connector type on both sides is it 4 pins or 8 pins pls let me know with details ur cam have firewire port i know but ur laptop i am not sure abt it pls tell me the model of laptop
if u dont have 1394 port on laptop then u have to buy a express card which have firewire 1394 connector or pcmcia card i dont know which card ur laptop supports after u tell me the model i can help
pls rate me for my help
Mar 06, 2009 | Sony Video Cameras
Sony Handycam DCR-TRV480 Digital Camcorder Logo
152 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
