Question about Polaroid FLM-3734B 37 in. LCD HDTV
Control Box How much does that part cost?
  • 298 Answers
Please see the link below to see the current cost for the Polaroid FLM-3734B Replacement Control Box.
Posted on Apr 22, 2008
Frigidaire ES400 range POP noise, now dead
At the cost of the control board I would suggest getting a service tec, preferably factory certified. If you buy the control board and it is not the problem you still bought it.
May 01, 2014 | Frigidaire Kitchen Ranges
I have used 2004 invacare torque sp power wheelchair in South Korea. Recently I have problems. When I turn on wheelchair in the morning, the power gauge is twinkling and it doesn't move. And it sounds...
A terrific resource for rebuilding wheelchair electronic control components is the manufacturer or a local dealer. Indeed, the best cost savings for this repair is an independant person such as Domingo Sanchez of Wheelchair Wizard in Citrus Heights, California. If possible, you should attempt to verify this is your problem component before going to the expense of repairing it. Domingo should be able to help you with this.
Oct 18, 2010 | Invacare Health & Beauty
Jacuzi M240 cannot get jets to work
It is most likely the control pad is bad, very gently pry it up going very slowly around the edges with a stiff putty knife or a blade, It will come loose, just be-careful and take your time. When you have it out, look at the bottom where the cable is attaches, if you see anything at all on the circuit board (blue/green oxidation, burns) the board is bad and will set you back 210.00 less shipping. If the board looks good, then it is the control box mounted behind the motor, this box will cost 320.00 less shipping. If you plan on keeping the tub, replace both control pad and box at the same time. Control pad no. M465000 Control box S474000 Both can be found on the internet by their part numbers on google.
Mar 13, 2010 | Home
The topside control panel is dysfunctional for turning on the jets. The on/off button doesn't work. The lights and temperature buttons work ok. The on/off button doesn't click on/off like the others.
It may be a bad control pad (topside) or control box (mounted behind the pump under the tub). I have replaced three bellavista control pad and boxes in the past 2 weeks. If you plan on keeping the tub have both the box and topside replaced. You can check the topside by gently prying it off the tub with a stiff putty knife or a blade of some kind, be very careful and take your time. When you have removed the topside, check the circuit board attached to the cable, if there is any corrosion on the board the topside is bad. It will cost 200.00 less shipping, the control box will cost 320.00 or more less shipping. topside part no. M465000 Control box part no. S474000 Both can be found on the internet under their part numbers.
Mar 13, 2010 | Jacuzzi Bellavista, 5.5ft Soaking Bathtub...
I have the same problem
I didn't but the control box,but found 2 caps inside it on the power board and replaced them both 10uf 450V.It fixed my problem
Jul 24, 2009 | Polaroid FLM-4201 42 in. LCD Television
When the climate control is shut off the fan runs at full speed. When the climate control is on it runs about 3/4 speed and cannot be adjusted
I have the same problem and took it to Firestone who said that I need to replace the whole climate control assembly which was going to cost me like $500, but I am not sure that I believe them.. have you found a solution?
Jul 09, 2009 | 2003 Chrysler Town & Country
Interior level indicator and interior lights not working on Whirlpool GD5RHAXNB00 Refrigerator.
The failed part on my unit was 2252189, the electric control board. This board is located on the left side of the refrigerator in the back next to the compressor. Its inside a plastic box on the side. That number has changed to a number WHIW10135090 and cost $84 from www.apdepot.com
A previous post listed a part number 2303805 as being the problem. That part number was the replacement number for the control board that is located in the control box inside the refrigerator. That part is NO LONGER AVAILABLE. It has been replaced by part 2255233 which is the entire control box. cost for that part is $161.00 from AP Depot. I purchased this part first and it was found to NOT be the problem.
I would suggest that anyone who has this problem start with the less expensive part 2252189 and them see if you need to spend more.
My unit worked fine with exception the the refigerator side interior lights and the digital display. Compressor and temperatures were fine. Just an FYI on my problem specifics.
Oct 25, 2008 | Whirlpool GS5SHAXN Side by Side...
FLM- 3732
Buyer74,
Yes, I did receive the control box from them. However, it was not functional either. I ended up taking my TV and both bad control boxes to a local repair shop. The one Polaroid sent me was the least expensive to repair since it only had a bad power supply. It still cost $189 to fix, but it's better than $400 for the cost of a new control box.
Polaroid has requested that I send them the bad one from my TV. I will not be sending it back to them unless they refund me for the cost of repairing the control box they sent me.
If yours works, then I bid you congratulations. If it doesn't, then have someone check the power supply 1st. You may even try switching the power supply from your old one with the new one and see if it works. Keep me posted.
Thanks
May 02, 2008 | Polaroid FLM-3732 Television
Power shuts off
Hi i am authorized repair center for polaroid. there are two ways this could be fixed. there are two capacitors that go bad in power supply that could be one fix caps will lookpuffedout, c112c113.
The other repair is replacing what is called the control box that is the guts of tv , it is simple to replace for a mechanical person. But the control box is expensive cost is 350..
To replace the caps you should be a repair tech cost is around 150to 200 to fix ,
thanks doctor video
May 01, 2008 | Polaroid FLM-3201 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
85 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
