Question about Goldstar R5203 Air Conditioner
The blowing wheel is loose and its making a loud noise when the aircondition is on. I took apart the machine and found the blowing wheel was chipped. Where can i find a replacement blowing wheel?
    President:
  • 1,515 Answers
Hi, this is a dual shaft motor, or most are. I have seen them chip or come apart. If the chip is large enough, it will put stress on the motor bearings over time as it will be out of balance. Take all of the information from the unit, model, serial, and product number if it has one, and if you do have the wheel removed it may have a part number engraved on it. The place to start would be at a appliance parts house for retail appliance parts. If they don't have this blower wheel, most of the time they can locate one of the exact wheel, or one that will work in its place. If they can't get one they should be able to lead you in the right direction to find one, I know for a fact they can order it from the factory as I have done this. This is your best bet. I hope I have been of help to you on this, as I know it can be a pain at times to find a part, but this should do it. Check the bearings on the motor to see if they are worn enough to have this wheel hit something to chip it. It may just have had a weak spot on it. Keep me posted on your progress, and please rate me kindly as I am sure you will. I will be here if you need more help. If so, send me all of the numbers from this unit and the name also.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 18, 2010
My 2004 Pontiac sunfire engine is making a knocking noise what could it be
Internal damage to the engine. Usually a knocking is a loose piston rod that connects to the crankshaft. When the rod bearing gets too worn, it causes the rod to become loose around the crankshaft, and you get that horrible knocking noise or rattle. The engine has to be rebuilt (very expensive) or a replacement engine must be found.
If the knocking is loud, and not a ticking (valves or valve lifters), then it won't be long before the engine is destroyed. Too much pressure on the loose rod-soon it may come apart and blow a hole in your block from the rod disintegrating. Not a pretty sight!
Nov 20, 2016 | Pontiac Sunfire Cars & Trucks
Whats wrong with my jeep?
don't use that mechanic again have the brakes and wheels checked sounds like a rotor or a drum has failed you.
Jul 17, 2015 | 2004 Jeep Grand Cherokee
Kenmore 90 series makes a loud noise during spinning and it looks like the basket is loose
On most Kenmore or whirlpool dryers, you have two wheels that have rubber around them. They look like wheels off of rollerblade skates. They simply bolt on to the back, but you have to usually put a large piece of wood to act as a fulcrum as you support the weight of the drum and change out the two wheels. Check with searspartsdirect.com for the parts prior to taking the dryer apart. I had a machine that sounded like tennis shoes were rolling around the drum and fixed the issue by simply replacing these two wheels.
Good Luck
Jul 23, 2014 | Kenmore Washing Machines
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Dishwasher makes a loud grinding noise when running.
Start by pulling out the lower rack. Then pull the nut off the top of the lower spray arm. then remove all of the visible hex head screws. lift up on this section. this should expose another level of hex head screws, then they should be removed and this section should be lifted up. once you reach the chopper blade, remove the obstruction, and put back together.
Mar 13, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Broken edge of bulb- TV won't work
The color wheel was the cause of the loud whining noise. The only item in the set under pressure that could possibly pop is the lamp. The fact that you have the 3 lights on is the lamp failure indicator. The lamp driver or ballast can also fail and give the same light error but I have never had one to pop.I would replace the lamp for sure. Also the lamp as you know sits right in front of the color wheel so perhaps it popped and fragments of the lamp ended up on, near or around the color wheel
Jan 11, 2009 | Samsung HL-R6167W 61" HDTV
Kenmore HE2 flashing lights
had an old pressure switch that I thought was the problem I had from something else a year ago
That was the washer not starting, all kinds of lights
I took the back and top off and reconnected all the plugs.
Had a loose connection somewhere, it worked after that.
I blew into it and put it back on.
The rattleing quit in the pump after it pumped out, while the drum was spinning slow.
Now working ok
Nov 24, 2008 | Kenmore 46462 Front Load Washer
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
Goldstar R5203 Air Conditioner Logo
95 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
