Question about Canon Office Equipment & Supplies
Is there any instructons or diagrams which show what each of the buttons on the left side of the printer is for?
  • 94 Answers
Go to http://www.retrevo.com/
find the manual that you are looking for... based on the model of your printer
Posted on Jul 19, 2010
Printing my e mails, I need AN OP ?
You don't need an OP button. actually, I have no idea what's an OP button.
To print, you need to connect your pritnter to your computer following instructons, install it using the drivers provided.
Then select the applicaton you want to use to wisualize your email and use print option,
Normally you don't need to manupalate your printer..
Jul 06, 2016 | Office Equipment & Supplies
I cannot find a plug on the side of my process drum to emty waste.
You can vacuum out the waste toner by removing the panel on the left or right side of the drum unit (can't remember). there is no plug. messy but it works
Jul 25, 2014 | Kyocera FS-1118MFP Laser Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Brother Printer 7820N I have part Numbers LM4249001, LM4225001, and LM4227001 but I'm not sure how to install them I need a diagram showing the parts. Help!
You have the drive link and gear and release lever that goes on the left side. You need to remove the left side, the circuit board, and the drive assembly to replace these. Only the Brother techs have access to the procedures and pictures, and we're not allowed to send them to anyone...Good luck with the repair!
Oct 28, 2009 | Brother MFC-7820N Printer
Just want to know if i can hook up a printer to my lenovo idealpad
go to system preferences
select print and fax
click the + button on the left hand side
A dialog will open which would show the printer connected to your machine.
Select the printer and say add, the printer is connected to the machine
Jun 29, 2009 | Computers & Internet
Waste ink absorber full - contact service center for replacement
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
Dec 16, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Changing the brakes
Parts for the front and rear brakes are readily available. I would recommend using the highest quality parts you can afford. Avoid discs or drums from China (poor metal). The easiest way I have found to do a car I have never worked on before is to take one side apart at a time and use the other side as a reference for reassembly. Good luck!
Nov 22, 2008 | 1986 Dodge D150
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
I need to know how to remove the stock radio from a 2003 ford taurus so i can install an ipod adaptor
Ebay has the tool for removal cost $1 plus shipping. this tool is for the 2 holes on left and right side of radio face fit tool in then push alittle out worad and pull. Follow aftermarket instructon on install.
Jun 15, 2008 | 2003 Ford Taurus
18 people viewed this question
old marine
old marine
