Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive
My 500 GB Western Digital External Hard Drive all of a sudden only shows 1 KB shortcuts to all of my file folders that were on it. I tried connecting it to a different computer and I get the same results. It shows that about half the memory is taken and all my folders still show up (but only as 1 KB short cuts). I cannot access any of the folders. It seems that the data is there but I cannot read it. What can I do to try and fix this problem?
I believe this is a trojan. I have the same problem. I found by going into Properties-shortcut tab- you have to rename the shortcut to the correct shortcut. You should notice some wierd file name like "keuiku.scr." Simply rename it to the original name and it works for me.
Posted on Aug 01, 2010
Download stinger and run in safe mode
Posted on Aug 03, 2010
  • isaac pontius Jan 07, 2011
    The folders and the files will still be there. copy the shortcut name... say for example the folder name was "QWERT" and was in the drive "E"(which might be your pen-drive), then in the adress bar on the top of your window type
    E:\QWERT.
    but don forget to use a good anti-virus to delete the virus from yr system.
    sircute6@aim.com
  • 34 Answers
Based on the question you described, it's probably caused by some virus or trojans which may make your file folders "hidden". Try the solutions from this article How to Fix File Folders Become Shortcuts. It should hlep. One more tip - Do not attempt to format the drive right away if you have important data insides the external.
Posted on May 05, 2011
Http://www.youtube.com/watch?v=vfjtJKHuP9QThis gets your data back but won't delete the virus from the computer you were infected with.
Posted on Feb 29, 2012
    Problem Solver:
  • 13 Answers
USB/SD Card files turning into shortcuts and/or disappearing WORM/Lodbak.Gen Virus!
(100% Complete solution including permanently removing the virus)
Lots of people are having the same problem with this virus. It spreads via USB memory sticks or external hard drives and cell device's SD cards converting all the files into shortcuts.
Fortunately the real files are still there, but unable to view/access these.
The problem is fixed in two processes:
Solution A - Retrieving the 'lost files' on USB/external hard drives/SD cards of cell fone:
This temporary solution is good enough to recover the data ONLY.
On Windows:
1. Click on 'Start'
2. Click on 'RUN'
3. Type 'cmd' and press ENTER
4. On the black Window that appears [technically called the Command prompt], write the commands shown below. Replace the letter X with the letter of your infected drive:
[For example, if your affected drive letter is F]
then the command:
attrib -h -r -s /s /d F:\*.*
5. After writing the command hit 'Enter' and wait a few seconds while the changes are made.
6. Go back to the 'File Explorer' and access drive F to see the files are back to normal.
7. In order to secure/recover/retrieve the data, copy and paste the data OFF or from the USB drive to your hard drive.
Solution B - Removing the virus permanently:
To eliminate the threat entirely and deleting the virus as a more permanent solution, there is no need to install any MALWARE softwares if a working and updated antivirus software is active in the computer. A file "WSCRIPT.EXE" in WINDOWS folder is responsible for all the infection caused by the [in my case] "WORM/Lodbak.Gen Virus!". In order to remove the virus from the computer, the wscript.exe file needs to be 'switched off' by taking the following steps:
1. Open Task Manager (Ctrl+Alt+Del)
2. Go to the Processes tab
3. Look for WSCRIPT.EXE that is currently running.
4. End the process.
Now, in order to permanently contain the WSCRIPT.EXE from reactivating again, its OWNERSHIP needs to be changed to deny further access. There seems to be no need to delete the file at this, or any later, stage.
5. RESTART THE COMPUTER IN SAFE MODE.
6.Go to Explorer Window, select "Windows" directoy"
7. Search for WSCRIPT.EXE. More than one may be found but changing properties of one will result the same for the other copies.
8. 'Right click' on the wscript.exe file(s) and select "Properties". On the dialog box that appears:
- Pick "Security" and then "Advanced"
- On the new dialogue box, pick "Owner"
- The "Current Owner" is changed to "Trusted Installer" by the virus.
- From the list called "Change Owner to:", select "Administrator".
9. Click OK.
10. As done in Step 7, again, Right click on the virus file:
- Pick "Properties"- and again "Security".
- This time, on the dialog that pops-up, click on "Edit"
11. A new (almost identical) window will pop up.
- Click on "SYSTEM" and deny "Read & Execute" and "Read".
- Repeat the same operation with all the elements of "Group and user Names"
After this is done, the computer will not be able to run this virus executable file.
Now, to take out the threat.
[I am going to refer those antivirus softwares which I used to eliminate the threat]
While still in SAFE MODE:
[Assuming your antivirus is up-to-date]
12. Scan the PARTITION C: completely.
- [I had AVIRA FREE ANTIVIRUS and it took out all the threats]
- The infectious files may include [in my and most of cases] WORM/Lodbak.Gen [worm] which was creating two m*.exe files in the PROGRAM DATA folder.
13. If not during scanning, or prompted for action later, delete all the identified threats.
14. Restart the computer in NORMAL mode.
15. Download and install KASPERSKY TRIAL ANTIVIRUS version.
16. After installation is done. Do NOT restart the system.
17. Uninstall the previous [in my case, AVIRA] antivirus software.
18. Once done, restart the computer.
19. Update the new Kaspersky antivirus database.
20. Scan the computer again for ONE remaining 'malicious' file and disinfect it upon prompt.
CONGRATULATIONS. Your computer is now 100% virus free.
[Additional Note: It took me around 10+ hours to finally resolve the issue. Now, its been more than a day when I finally decided to close this chapter after trying and testing around 9 different USBs. The shortcut issue is not popping up anymore and everything is working fine with USBs and data remained intact, and not disappearing.
The reason I used Kaspersky in the end, its trial version did the job without asking purchasing of complete version. I google and tried many malware softwares but each one failed to remove the virus. They all found something suspicious or threatening but demanded full version through purchasing in order to remove these.
Once the trial period is over, I'll be resorting back to AVIRA which did in fact traced and deleted the virus from the computer in the first place but got itself infected during the process of my search for solution and experimenting. It's 'realtime protection' was disabled and was not being enabled. Other than this, Avira remained an outstanding experience since the last 3 years I've been using it. Somehow this screwup slipped past.
I hope my this experience helps those who are still out there looking for a solution.
Have a nice time hunting the virus, folks.]
Posted on Jul 21, 2015
  • 121 Answers
Yes its a virus call "autorun". to get all the files in the folder that has become a shortcut, its simple.
1. you will need to do these steps on a computer with antivirus installed and updated.
2. access your pen drive partition
lets say that the folder that have been shortcut name is "Y"
3. on the address bar, type the name of the folder name, you will see
y.lnk will appear, remove the ".lnk" and press enter.
4. you will get all the containing in folder, copy all files and paste it on your desktop in a new folder, continue with all other folders.
5. after you done with the transfer of all your files from the usb, you can format the usb drive and transfer all your files back to the usb drive.
i suggest you to install a good usb antivirus on your computer and make a scan of all your partition, this virus can infect all your folders on your system and infect other usb drive, and when using the infected usb drive on other computer it will automatically infect the computer.
hope this will help you get all your files back.
good luck
Posted on Nov 24, 2014
Could be a format problem, ie transferring the HD between a Mac and a Windows laptop or PC. If you have done this, then mac may have formatted it to be readable on a mac only, as was the case with OUR Western Digital external hard drive... problem solved for me anyway.
Posted on Sep 16, 2011
    Problem Solver:
  • 10 Answers
I would STRONGLY suggest downloading, installing and updating the free versions of Malwarebytes AND AVG and then running a FULL scan (not a quick scan).
After downloading and installing these programs be SURe to update them.
I have similar problem, if you get the solution for this, please let me know also..thanks in advance
milind
milindsw@gmail.com
Posted on Jul 19, 2010
  • mannymend Aug 18, 2010
    Use stinger.exe and run it on all your drives. This fixed the problem for me. Good Luck..
    Manny
  • kazzdee Sep 16, 2011
    Have you used it between a mac and a windows laptop, if so, it could have formatted itself to a mac drive. I found this to be true while looking on this page and desperately trying the drive in my mac after my boyfriend had the same issue on his laptop. Our problem is solved anyway! :)
2 Suggested Answers
SOURCE: My folder's turned into 1
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
Posted on Dec 07, 2011
My external hard drive (wd) not showing the datas, but its occupied space.. how to get my datas from this...?
may be its hidden.
Select show all hidden folders in ur computer
still not showing then the virus have affected it u cant get back data
Jan 31, 2013 | Western Digital Elements powered by WD 320...
Why is there a question mark on my WD My Book 500 external Hard drive short cut?
Wow, Im amazed at the guy who threw his WD into the freezer for a week after a fatal crash and was able to get most of his stuff back! I was so frustrated after my second WD crashed that I gave up and used it as a door stopper. I was too bummed out to even bother returning it for an exchange, and when I did think of doing that, it was too late. I decided never to buy WD again, their drives are pure junk!
Reply to:My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive)
Jan 03, 2012 | Western Digital 500GB My Book World...
  • 100% free
DOWNLOAD !!!
Feb 15, 2011 | Western Digital My Book Essential Edition...
I have the same problem with my WD 500 gb. Ii has been working fine everyday, and suddenly it lights, and I can see it searching, but the files will not come up. I get a box on the screen asking me if I...
The disk-drive inside the casing is "dying".
The "table-of-contents" (listing all the files/folders on the drive) cannot be read.
Check the warranty-status of the unit -- if the warranty-period has not expired, then Western Digital will replace the MyBook, at no cost to you.
Sep 30, 2010 | Western Digital 320GB MyBook External USB...
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
Aug 18, 2010 | Western Digital My Book Essential Edition...
230 gb drive with 100gb used and only 70gb of free space showing
please check if the files are hidden. just go to the explorer -> tools -> folder option -> view tab -> then on the Advance Settings click the Show Hidden Files and Folders. then try to navigate your external hard drive.
Jul 02, 2010 | Western Digital WD Passport 250GB Portable...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
I cannot create new folders on my external HD
If the explorer shows you have some space left and can not create any file or folder, it might be because of heavily fragmented drive. try defragmenting thr drive using any application. I usually use O&O defrag .
Sep 16, 2009 | Western Digital My Book Essential Edition...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Wd problems
Change the drive letters, worked for me. I have 2 WD My Books, I made one R: and one S: worked fine after that. On vista go to Control Panel -> Classic View -> Admin Tools -> Computer Management -> Disk Management -> Right click on WD drive and change letter. For some reason G, F, E, ect seem to run into some problems
Dec 06, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
11,407 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
