Question about Bosch Classixx WFL 2066 Front Load Washer
My Bosch washing machine doesn't add the softener from its compartment
  • 24 Answers
The first thing you should do is check the compartment from the fabric softener. If something is blocking the exit of the softener, the machine will not add it.
If you checked the exit or the holes in the valve of the fabric softener compartment and nothing seems to be stuck there, there could be a problem with your washer's timer. Check the timer and get a replacement for it.
source: http://www.washingmachineadvisor.com
Posted on Mar 30, 2011
Why does my Samsung washing machine discharge the fabric softener before the washer has added the water?
The addition of the softener is dependent on the level of the liquid in the drawer.
If you add too much softener to the drawer compartment then the liquid will immediately flow into the drum of the machine, you need only to add softener up to or preferably just below the line marked in the compartment. Also, if you slam the drawer shut then a wave of softener level may cause it to flow into the machine before the start of the program.
Nov 03, 2017 | Samsung Washing Machines
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
Softener wont add
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.1_15_2013_10_08_16_pm.jpg
Jan 15, 2013 | Belling SGE12X Front Load Washer / Dryer
Which comaprtment for the washing liquid ?
Compartment 1 is for Pre Wash
Compartment 2 is for Main Wash
Compartment marked with what looks like a star is for conditioner.
Bosch manuals can be downloaded from www.bosch-home.co.uk
May 19, 2009 | Bosch Dryers
Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
May 01, 2009 | Bosch Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Adding detergent/softener/bleach
U cud, but not recommended as it cud lead to oversuddsing, causing all sorts of prob's.
Stick to recommended doses.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Water remains in fabric softner compartment
Is the softener entering the machine; that is at the appropriate time? You can take a peep at this time, if possible. If it is water it is okay; this is just the remaining water. The softener is dissolved with water and flushed into the machine.
Dec 05, 2007 | Bosch WFMC 3200 Front Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Classixx WFL 2066 Front Load Washer Logo
142 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
