Question about Maytag Washing Machines
Maytag Neptune stacking washer, model #MLG2000AWW, sounds like a jet engine warming up during spin cycle. Otherwise it is quiet and works well. Is a main bearing going out? Is it something I can fix myself, being pretty handy and all?
  • 1,998 Answers
You can but it wouldnt be economical to fix it if it sounds like a jet it is yr rear bearing and although the part might be only 60 dollars the amount of time it would take someone to do the job correctly is about 2-3hrs if you can do the job yourself then you would save on a large labor bill ive seen some techs price doing this job at starting prices of 400 you can find the part at marcone appliance parts if you choose to do the job yrself hope this helps
Posted on Jul 18, 2010
Maytag staced unit neptune model MLG2000AWW doesn't go into spin cycle what do I look for?
Posted on Sep 01, 2010
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Noise
YEA!!!!!! thats a bad rear bearing, depending on age, id call a local authorized maytag servicer and see what they get to repalce it for you, perhaps you still have a part warr on certain parts, otherwise irts not worth the cost of repair
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
440 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
