Question about Dell Dimension 3000 PC Desktop
My C drive and Backup E drive are switched
My C drive and Backup E drive are switched everything is saving on the backup not primary how do i switch it
  • 76 Answers
You ned to change the save path file. For a short answer...Try clicking "save as" instead of "save" there should be a dialog box prompt that lets you select where you wish to save your documents.
Posted on Jul 22, 2010
Where is the backup light switch located on a 1997 Mercury Cougar
There isn't any switch. Instead 12V output from the 10A TUR SIG FUSE in the primary junction block is applied to the transmission range sensor which, in the R(everse) position turns on the two backup lights.
Oct 28, 2014 | Cars & Trucks
NEED A KEY FOR A MQ8800E GENNY
If you didn't make backup keys, either call a locksmith or unscrew and replace the entire key switch. If you go with latter solution, keep the original key in a safe place, make backup keys, then use the copied keys as primary in your key ring while the original keys are emergency backup. If you loose your key ring, create more keys with emergency backup (original) key. NEVER use the "original" key as primary, or otherwise the copies made from copied key won't fit right.
Nov 07, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
How to reset everything on my ps3?
Hard Reset procedure for the PS3 (as instructed by Sony CS). Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
Arvind S Iyer
Oct 17, 2010 | Sony PlayStation® 3 (60 GB) Console
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Problems with line 2 not connecting properly
I have encountered similar problems connecting equipment to two lines. Open the terminal block so you can see the wire connections. Line 1 should be red and green wires; line two should be yellow and black wire. If your installation is new, you may see WHT/ORG and ORG/WHT and WHT/BLU and BLU/WHT wires or some other combination selected by the telco technician on a whim. The color combination could even be reversed or one side of line one could be connected to one side of line two - a typical "Monday morning" installation. If you make sure the line wiring is correct everything should be working correctly.
Mar 29, 2017 | RCA ViSYS 2-Line Speakerphone
Low local disk space
get a external usb hard drive.you cant do anything to a computer like this chap its going to cost u a little someing.i hope this help u
Jul 18, 2009 | Compaq Evo D300 PC Desktop
None of my settings will appear
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
this will reset everything and make it like the day you brought it so u will lose alot of info but you will bebale to use it again
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
How do i change from spanish to english on my ps3
Please rate, thanks
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Dell Dimension 3000 PC Desktop Logo
Clive
Clive
Alun Cox
