Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Poulan countervibe 3400 clutch removal - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
    President:
  • 2,220 Answers
Hello DJ; I suspect she is has some age. The IPL I found (below) shows an outboard clutch and no chain brake.
http://www.ordertree.com/modelinfo/PWE/3400-Gas-Saw/75.3400-Gas-Saw.1.59.1.html it may be helpful with disassembly. Clutch detail is on the "Handle Bar Assembly" print.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
3. Most (99.9%) clutches have left hand threads (tighten it to loosen it). If a finger nail held in the thread and rotated clockwise comes off the shaft it is a left hand thread. If it pinches against the clutch it is a right hand thread.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 18, 2010
I have poulan countervibe 3700 chainsaw, starts great, revs up nice but when I go to cut it lacks power especially cutting sideways. it finally will stall.
The diaphragm in the carburetor allow the unit to run upside down or sideways. I think you may have a diaphragm that is not pumping fuel well. Rebuilding the carburetor may fix the issue.
Oct 08, 2017 | Poulan Garden
How do i remove clutch assembly on a poulan 445 pole saw ?
First you need to remove clutch drum. Inside the center is a trox that need to be loosen to remove it. Then you will to remove the spark plug so you block the piston movement using a piston stop or fill the cylinder with rope. The itself is left handed threaded and there will an indicating arrow on it as which way is off.
Jul 29, 2014 | Poulan Garden
How to install clutch on poulan pro 42 cc
Remove the clutch hub and sprocket, then using a Poulan clutch tool, unscrew the clutch assembly and replace.
Jul 25, 2014 | Poulan Garden
Do you have an owners amnual for a 1983 Poulan Countervibe 3400 chainsaw?
Follow this LINK. If it doesn't work, let me know. I know it says Husqvarna, but that is because Husqvarna owns Poulan, but this is a poulan manual.
Mar 07, 2011 | Garden
Poulan Countervibe 3400 will not start
In all of those years, the fuel and oil lines will have deteriorated as well as the rubber components in the carburetor. The fuel filter in the tank is probably also plugged. Remove the spark plug and check for spark--it should be blue and snappy. Check the condition of the primer bulb--it should be soft without holes or cracks. Try some fuel in the cylinder head and reinstall the plug. It should pop a few times if in firing condition. Replace the air cleaner and check the muffler for plugging. Pretty much a major tune up! Hope this helps!
May 22, 2010 | Garden
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
How to remove the clutch from a poulan prolink
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool.... b61de2e.jpg
Jun 09, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How to remove clutch on Poulan Pro PPB350 gas trimmer
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwainb076e56.jpg
May 18, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Apr 07, 2009 | Poulan Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
245 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
