Question about Estate TEDX640JQ Electric Dryer
Hi. My sister's dryer won't heat. I have taken the
Hi. My sister's dryer (actually a TEDX640PQ0, not TEDX640JQ) won't heat. I have taken the back panel off but don't immediately see the heating element area. Where is it? I see 2 silver cylindrical metal housings going down the back. Do one of these come off after the back panel. Thanks.
  • Estate Master
  • 3,361 Answers
Facing the parts from the rear,the heater is on the right hand side.
It can be removed from the bottom of the cylinder.
There is a thermal fuse on the top left side of the heater canister. Remove the wires from it and use a volt meter set for ohms. Test the fuse. No reading is a bad fuse. It comes in a kit with the high limit thermostat located on the base of the heater. They must be replaced at the same time. If the fuse is good,use the volt/ohm meter to test the heating element. No reading is a bad element.
Posted on Jul 18, 2010
Dryer drum rotates but there is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Estate TEDX640JQ Electric Dryer
How can I get the top off the dryer to check the heating element
Hi, the top to your dryer is opened by pushing in clips on the right front and the left front with a putty knife while lifting. It then folds back, make sure to prop it securely. Hope this helps.
Jan 19, 2011 | Estate TEDX640JQ Electric Dryer
Dryer not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | Estate TEDX640JQ Electric Dryer
Dryer runs but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Nov 06, 2010 | Estate TEDX640JQ Electric Dryer
Electric dryer not heating
heatman101
Oct 31, 2010 | Estate TEDX640JQ Electric Dryer
Dryer wont heat
heatman101
Sep 27, 2010 | Estate TEDX640JQ Electric Dryer
Doesnt heat
heatman101
';'l
Sep 21, 2010 | Estate TEDX640JQ Electric Dryer
Will not put out any heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 20, 2010 | Estate TEDX640JQ Electric Dryer
I have an estate TEDX640PQ0 Dryer that won't get hot. I Replaced the heating element but still nothing
heatman101
Jun 12, 2010 | Whirlpool TEDX640PQ Dryer
Estate TEDX640PQ0 electric dryer makes grinding noise when running and seems harder to turn drum
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
175 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
