Question about Razor MX500 Dirt Rocket
My razor dirt bike charger blinks green what does this mean?
5 Suggested Answers
  • 71 Answers
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
bozcro
  • 867 Answers
SOURCE: my razor mx350 battery charger blinks green when
green should mean charge is complete
Posted on Aug 15, 2009
  • 16 Answers
SOURCE: can you put training wheels on a razor 350 dirt
no unless you get them custom made
Posted on Jan 26, 2010
SOURCE: where do i get a battery for a razor dirt bike?
razor.com they have alot of replacement parts
Posted on Dec 31, 2010
How long do you have to charge it for? , and do i leave it on or off?
the Razor MX350 will accept a charge if powered on or off, charging time is 8 hours, if the green light shows before this time still leave it plugged in as it may not be reading right.
Jun 25, 2011 | Razor MX350 DIRT ROCKET - BLUE
Charger keeps flashing red and green and wont charge
Look at the connector end that plugs into the bike. You might have to take it apart to see the wires inside. My son has a Razor Vespa type scooter and the solder job for the wires inside the connector were not the best. It might be a broken wire, especially if it's flashing between red and green.
Hope this Helps!
Please Rate;)
Gary
May 25, 2011 | Razor MX500 Dirt Rocket
Problem w/ razor dirt quad. I replaced the control module, it ran for a few days then died. Bought another control module and it doesn't go at all. I checked the batteries and they are putting out just...
Well this post was done a long time ago, seems like you have a bad battery. you should see 24vdc. The batteries are in parallel so it adds up to 24 volts.If one of them is dead it would only show 12vdc.
Sep 06, 2010 | Razor Dirt Quad Bike
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
Charger flashes red, does this mean it is still charging or is there a problem?
red means it's done or not connecting to charge. Green lit when excepting charge
Feb 26, 2010 | Razor MX500 Dirt Rocket
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Razor MX500 Dirt Rocket Logo
89 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
