Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door starts to go about 10 inches stops and reverse and stops the light at the push button flases code 5
  • 504 Answers
You may have a broken spring.
Does the door work manually.
If it works manually replace the rpm sensor - if it doesn't replace the spring(s)
Posted on Jul 18, 2010
How do i take a time delay pic with my canona550 camera
I don't have your exact same camera but on mine you push the menu button, go to tolls and you'll see settings like +1 , +5 +10 these are the delay times once you select one you push the shutter and mine beeps and then beeps faster as it gets closer to the time out and then it takes the picture ( this is handy for taking pictures of yours elf and mine has a little light on the front that flases as it counts down and it stops after to takes the picture.
Apr 03, 2011 | Canon Cameras
How do i program my rca remote to my 42 inch samsaung tv
you can try a code search
  1. Turn on the tv you want to program.
  2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
  3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
  4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
  5. Press and hold the stop button until the light goes off. This saves the code.
Mar 03, 2011 | RCA 3-Device Universal Remote
I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 139.53673SRT garage door opener. When I try to close door with remote or single push on doorbell control, the door reverses after 6-8 inches of travel - and big bulb flashes 10 times. ...
When the main light flashes 10 times and the door reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor or wiring.
Aug 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 HP garage door opener will go up fine with the push of any button, but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. If they aren't lit tweak them a bit. If they both won't come on you have a bad sensor or the wiring leading to it.
If the main light doesn't flash 10 times you can increase the 'down force' which is a control on the rear of the motor unit. Increase this just a bit and try.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener will not work. model # 139.53648SRT2
The code it is sending by flashing 5 times is 'RPM sensor or motor overload'. Is the door stuck in the open position?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
191 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
