Question about Maytag Neptune MDE5500AY Electric Dryer
Our Neptune only blows super hot air. Which may sound good but it is ruining the clothes. It will not blow cooler air at all. Seems like this problem started more than a month ago. Is there an easy fix for this
    Brigadier General:
  • 4,088 Answers
Clean the lint out of all air passages including the exhaust hose to the outside. Wash the lint filter in hot water and detergent to clean away fabric softener deposits which block air flow. Make sure that nothing is obstructing the air intake for the machine. If the problem continues, the heater thermostat may need to be replaced. Hope this helps!
Posted on Jul 18, 2010
Testimonial: "Quick response and appears to be dead on accurate, Thanks"
Problem with heating up and staying heated.
Thermostat is sticking or heater core is blocked.do not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Apr 16, 2017 | 1997 Oldsmobile Bravada
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Mde4000ayw  It runs and hot air comes out the exhaust but clothes take for ever to dry. Help?
Sounds like you may have lint stoping up the vents it could still get some hot air out but not enough. Or maybe one side of the 220 power line has kicked the breaker or a burnt wire in the dryer.Check the outside vent it should be blowing as much air as coming out the dryer.
Jul 16, 2010 | Maytag Neptune MDE4000 Electric Dryer
2003 Ford F250, the heater does not blow hot air
check the heater temp. control pot under the hood, inline on one of your heater hoses, it may be sticking causing hot water to only get to your heater core when the engine is at high r.p.m.s
Oct 31, 2009 | 2003 Ford F250 Super Duty Crew Cab
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Air Conditioner blowing hot air
if your a/c is blowing hot air your system needs to be discharged and recharged with redtek a/c at your local canadian tire store.
Jul 23, 2009 | 2001 Daewoo Nubira
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
My Dimplex DAC12AC aircooler is blowing out hot air
Hi,its possible have a problem your PCB Board ,the 17c is so cool setting but blows hot , and the E3 simble its min High Cooling , pls check ur PCB board to the nearest service center.
Jan 07, 2008 | Heating & Cooling
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
