Question about Royal PX110MX Shredder
Cant access blades
Want to take outside off of the shredder to get closer to the blades to service them. Can someone tell me or provide a link to take the unit apart?
Thanks
Todd
    Genius:
  • 1,218 Answers
Remove screws from underneath to separate top from bottom of shredder..once the top comes off your in business.
Posted on Oct 10, 2010
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
Staples SPL QW1200 shredder - how to disassemble it to get full access to blades?
remove the bin, remove thr screws that hold the bottom on (to get the cord free) then flip it over so its sitting on top remove the screws around the side walls to the top and remove the top shredder. with the shredder still up side down there are 8 screws around the outside edge (in the 1/4 holes) remove those and you can seprate the housing from the blades and motor. in the one i have the blades in the center are bent and the guides are broke i am looking for replacement parts or another for spare parts good luck i am a automotive tech, and i hate to throw things out just because ond small small part is broke but the hardest thing is finding parts. we live in a world where we are in couraged to reclye but we throw so much away because it is almost imposible to find parts or when you do the replacment parts cost more than a new one. sorry for the rant but i like to see people trying to fix things
Sep 09, 2012 | Office Equipment & Supplies
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
Apr 11, 2012 | Office Equipment & Supplies
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
A hair pin was put through our shredder by mistake and it became jammed. We cleared out the shredder and removed the hairpin however now the shredder does not operate. It will operate in reverse if you...
Yes small shredders don't like to shred metal.
You have probably blown the pcb inside the machine...would need to know make and model to provide further access for parts.
Aug 11, 2010 | Office Equipment & Supplies
Paper has collected around the shredder blades. I
Remove the cutting head...remove the top plastic cover to gain access to the inside...clear paper from inside and reassemble.
Oct 12, 2009 | Royal VF1000MX Shredder
I want to encrypt my router so it cant be accessed by someone outside my house i have a d-link di-514 thanks
>Goto your router/modem settings
>Choose your wireless security and create a network(ie access code) key to provide security to your router from unauthorized access..
Aug 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Royal PX110MX Shredder Logo
141 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
