Question about Samsung DV448AGE Gas Dryer
I removed the control panel and then the five screws on the stainless strip above the door, however the front panel is not lifting off as described in the gas conversion help.
  • 10,865 Answers
  • tomp166 Jul 18, 2010
    Hello Joe, I can see the diagram, but my front panel just don't want to pull up!! could there be screws somewhere on the bottom of the panel? if there are I cannot see them.. I appreciate any help..
Need to remove front panel above oven door to replace control panel. have reomved the screwws along bottom of this panel but it does not move enough to access anything. how do i get in to the control...
Remove two screws beloe the panel just above the door. There might also be two screws, one on each side/end of the panel.
Lift panel to loosen. Sometimes grease makes it hard to come lose.
Oct 03, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Removing rear interior panals
Remove one Phillips screw from leading edge of door panel (near latch). Remove small cap behind the door handle, inside another Phillips screw - remove screw and then the cup behind the handle. Look down in arm rest and there is another Phillips screw. Last screw is behind the approximately 1 1/2 inch plug on front upper corner of panel. At this point, gently pry around lower edge and sides - there are either five or six clips pressed into the door frame. Once all are disengaged, gently swing the bottom of the panel out and lift off the top edge of door next to window opening. Once panel is off door, gently remove the control plug from the door lock/window control on the rear of panel. Install in reverse order
hope this helps
May 04, 2013 | 2005 Mazda Tribute
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
I need to remove the wood door panels on my sub zero to repair a door handle
I have subzero 642 but it should be the same. Remove 2 screws on the top edge of the door. The screws attach a metal track to the top of the door and the track needs to be loosened to allow the front wood panel to slide out. Next on the side edge of the door are 3 metal strips. The middle one is held in place simply by magnets and slots at the top and bottom edges of the door. You can remove the middle strip by lifting it out in the middle with a small screwdriver and pulling it off. This will expose 3 or 4 screws that hold a metal track to the side edge of the door. Remove these screws and the metallic track on the side edge of the door. You can then slide the wood door panel out enough to expose the 2 screws that the door handle attaches to. Good luck!
May 16, 2010 | Sub-Zero 632 / S
How to remove front panel on a dle3777
Disconnect power to the dryer and remove the three screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off.
Remove the two screws attaching each side of the control panel to the dryer cabinet and disconnect the wires from the control panel. Pull the control panel upward and then forward to remove it from the dryer cabinet.
Open the dryer door and remove the two screws from the bottom of the door opening and then the four screws securing the top of the front panel to the cabinet. Disconnect the door switch wiring harness and remove the front panel from the cabinet.
Just reverse the given steps above when reassembling the dryer.
Apr 12, 2010 | Dryers
Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Mar 25, 2009 | Refrigerators
Samsung DV448AGE Gas Dryer Logo
42 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
