Question about Toys
We have the Craft Couture bead kit but we are missing the directions. You are supposed to place the small plastic beads in a holder to make a pattern and then iron over it to make it all fuse together. However the beads are not fusing together they only stick to the cloth beneath the iron. What type of paper or cloth should we use under the iron how long to iron etc?
    Scholar:
  • 135 Answers
You should be using Parchment Paper. We used Wax paper too, but it doesn't work as well. Ironing times vary depending on how much you want them to melt. We have melted some to the point they no longer have the holes in the middle of the beads and others just enough to stick the beads together. The barely ironed ones tend to fall apart eventually. The fully fused and melted ones are permanent.
Posted on Sep 16, 2017
  • 48 Answers
SOURCE: Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Posted on Jun 18, 2008
  • 68 Answers
SOURCE: roof leak 1999 jayco eagle mod 8333-8715
It is best to get self tapping screws and relocate them. The water leak has destroyed the wood where the factory screws were and a bigger screw will not work. Just move them over a few inches. If the leak was bad enough all of the wood will be routed and should be replaced. Is this on the top seam where the rubber meets the aluminum or is it on the side of the camper near the top?
Posted on Mar 24, 2009
SOURCE: My tubeless tire on garden tiller leaks at the bead.
if the rim is clean it should seal i had a hard time on my loader i used mr gasket brush on no more problem
Posted on Mar 30, 2009
sgoldberg08
  • 57 Answers
SOURCE: Hi my name is Nick
If the bead maker is putting 100,000 beads into each box, then it will take her 10 boxes to package 1,000,000 beads. To package 4,000,000 beads (which is 4 times as much as 1,000,000), she will need 40 boxes. An additional 3 boxes (we're now up to 43 boxes) will allow her to separate a total 4,300,000 beads. Bead number 4,358,216 is between bead 4,300,000 (requiring 43 boxes) and 4,400,000, and she will need another box to package those beads, so we can deduce that bead 4,358,216 will be placed in box number 44.
If you found this solution helpful, please leave a positive rating!
Posted on Aug 30, 2011
SOURCE: Can I get a speed bead manual?
I've uploaded the manual here: <a href="http://www.mediafire.com/?ea6wwo8e9gcgnku" target="_blank">http://www.mediafire.com/?ea6wwo8e9gcgnku</a>
Posted on Nov 15, 2011
Can I modify poorly applied lumpy window caulking without compromising the application? How important is a smooth bead, especially around my south facing Windows?
You can safely cut off the old caulking with a craft knife/box cutter and apply new silicone. You can buy a very cheap tool to mould the beading. Mask a line with masking tape about a quarter inch from the join on the surfaces. Apply the bead of silicone and remove the tape after 5 minutes. The bead doesn't NEED to be smooth, it just needs to seal to stop ingress of water.
Sep 16, 2015 | Computers & Internet
I bought some beautiful beads for making necklaces etc but some of the holes are just a bit too small for the thread. Is there anything I can do? It seems such a waste not to use them.
Do you have a bead reamer? If you bought a starters jewelry making kit, you might have got one with it. If not, you can buy one for quite a good price. Bead reamers are good for smoothing down rough edges on beads but can also help to enlarge holes on beads.
Jan 10, 2013 | Crafts & Hobbies
How do I get a bad smell out of plastic beads?
naturally, plastic beads has a bad smell. But, you may also try to soak that on a water with soap :) hope this helps
Dec 07, 2012 | Refrigerators
What do I replace the little red bead with?
I superglued a bead close to the exact same size in it's place and it worked for me. The bead must be round and smooth (w/o any glue residue or hole on exposed surface that the ball touches on) else the movements are a bit jerky and it's hard to control. Hardest part is finding that bead size. Perhaps a bead store?
May 19, 2012 | Kensington Expert Mouse Trackball
My problem: "PF" error code keeps appearing. (an
To install the Ferrite bead kit its just simply clips over the main power cord...i have included a few pictures of ferrite rings(beads) oldtech2332_141.jpgoldtech2332_142.jpg
Oct 14, 2011 | Whirlpool 30" Freestanding Gas Range -...
Hi my name is Nick I have 1 question. Suppose a bead maker wants to separate 10,000,000 beads into boxes. She will put 100,000 beads into a box. Into which box would she put the 4,358,216th bead?
Aug 29, 2011 | Computers & Internet
Phillips Elect North Amer Model AT500 aroma bead lamp
I have the AT500 Philips aroma bead lamp but cant find the beads to put into it. Can you send me in the direction as top wear they can be found? I love my lamp but its just not the same without the scent.
Please email me at evamariefrank45@gmail .com
Thank you, Eva
Dec 30, 2009 | Kitchen Appliances - Others
Murano bracelet watch lost 2, small white beads & looks lopsided
Wonderful company I bought Murano Millefiori watch from here in USA is replacing for me per today's e-mail which came same morning as your.
This site is very interesting and will keep it for futher use!
Thank you for wanting to help me!!
Debbie
May 16, 2009 | Murano Millefiori Firenze Bracelet Watch
Toys Logo
37 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
