SOURCE: oil leak
ok ill try not to tell you rear main seal. but i can;t it sounds to me like they may have over filled it and as a result that will blow seals. i mean it is very easy to fix. and yet very expensive. also check the place where they put the oil into and check the oil pan gasket. use some break cleaner on it and clean it then add oil run it and check it
SOURCE: Exhaust tube not staying in collar/not sealing correctly
Screw it back in place and put a sheet metal screw in it into the adapter.
SOURCE: My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
