Question about Microsoft Xbox 360 Console
Xbox scratches my disks
I dont have it vertical, dont touch it when the disk is in.
it doesnt get moved at all but it still scratches my disks.
i bought a gears disk and within 24 hours i took it back, then the 2nd scratched instantly and i had to take it back but the 3rd one hasnt scratched at all !?!?!
i would like to know how i can fix it myself seeing as my warranty ran out and its £60 for a repair.
my halo 3 disk is now ruined aswell.
Ive read about it mayb being a manafacturing fault with the disks and this could be true seeing as this 3rd disk is virtually untouched.
  • Anonymous Apr 29, 2008
    hiya, my stepdad phoned microsoft and had a massive go at them about disk scratching.
    if you phone them up and shout quite a bit, you will realise you will not get anywhere.
    then tell them either they fix it or you will sue them like a load of others are suppost to be doing , and also say i will go to watchdog.
    if people look at the article , please email watchdog and keep sending your problems,if so, then microsoft will get there asses into gear and will be made to re-emburse us with the money
    Problem Solver:
  • 9 Answers
Another cause of this problem is due to certain toshiba drives (i think its the toshiba) but there is a magnatised section at teh top of the drive which latches down onto the drives spindle.
This again is a common overheating problem. due to the heat the glue used on the spindles center becomes loose, the center section which then holds the disc in place is attracted to the top peice due to the magnatisim.
This results in nothing holding the disc in place when it is inserted, when the drive spins the spindles still manages to spin the disc, but as mentioned its not held in place and the disc is exposed to the underside of the spindle center causing teh scratches on the disc. This problem is often identified by iregular scratch paterns on the disc or servere scratches.
The solution, call microsofts repair department, they are fixing all consoles as a good will gesture despite warrenty status. if you would prefer to fix this yourself, simply take apart your xbox 360 and remove the dvd drive. and screw the drive and you should see the loose spindle section stuck to the top section of the drive.
You can use a headed glue gun or other heat proof glue to attach it back in the correct place, make sure you align the 3 holes correctly when gluing back into place.
Hope this helps
Anthony Kinson
Posted on Apr 22, 2008
    Problem Solver:
  • 17 Answers
The solution is the Optical drive starting to Fail, as this is a defect in the unit, it is only covered under warranty. What is happening is that when you reach certain points in the games the system buffers the data from the disc into the system memory and when it buffers all the information it powers down the Optical drive causing the disc to spin down abruptly without letting the laser seat back into the housing properly. causing the disc ring of death. One of two solutions is to resurface the disc or replace the Optical drive.But By searching the internet you can find an inexpensive replacement.
PAEASOP
My game is scratched due to my daughter moving my console
The only soulution is to get a disk scratch remover to rescue the disk. The Xbox scratched the disk because of the lack of anything to stop the disk tilting inside the drive when the xbox is moved.
Jan 03, 2012 | Microsoft Xbox 360 Hard Drive (120GB)
Hi when im on mw2 when i go on to rust the map on xbox live it says i have to clean the disc but when i clean it it stil doesnt work and all the others maps work just rust and rust is my favourite map
it sounds more of a scratch error than just cleaning it. it may have been scratched if you moved the console while the disk is moving then it may have scratched it. to be sure see if possible you can test your disk on someone else's xbox to see if its just your xbox.
Aug 26, 2011 | Video Game Consoles & Games
How do i tell if my xbox 360 is the probelem or my disk
just make sure your xbox is on a solid surface and that u dont move it at all whne it on
Apr 18, 2010 | Microsoft Xbox 360 Console
Disk scratch
theres something wrong with the xbox
Mar 21, 2010 | Microsoft Xbox 360 Console
Not reading disk
Disk Problem:
you need to check the back of the disk and check for scratches. if there are scratches then you need to rub white toothpaste on it. make sure the toothpaste is smooth and doesnt have any hard substance in it. then once you put your toothpaste on, rinse it all off with medium pressure water. when you cant see anymore toothpaste, dry the disk with a very soft cloth. test this in your xbox. you may have to repeat several times. if this doesnt work, it is likey you need a new disk.
Dec 07, 2009 | Microsoft Xbox 360 Console
I down loaded mythic pack played for one day then
it sounds like there is a problem with the disk drive (not aligened properly) as for the mythic pack check ur hdd is in properly and that it is on ur hdd if not i am sorry im more hardware than software as for the unaligned disk drive u can get another one fit it personally and have the warranty go or go to xbox .com and put a repair in
if this doesnt help or not in enought detail then please ask
Sep 02, 2009 | Microsoft Xbox 360 Console
My xbox scratched my game
The first xbox models had the same issue, I my self experienced it, but it was only once.
Replace the drive or talk to microsoft if it happens again
Jun 21, 2009 | Microsoft Xbox 360 Console
My Xbox 360 intermittently scratches the game disk
1. you move, shake or touch xbox while running or disk is iin. solution: STOP!!!
2. The disk reader is to close to the disk. Solution: Open up xbox,. find disk reader, take picture. Show to people at game-stop, they'll tell u what to do.
3. Xbox is broken or faulty Solution: Get your money back and buy a new one or don't and keep buying games when the old 1 gets scratched
Jun 17, 2009 | Microsoft Xbox 360 Console
Scratches my disks
If you move your xbox while it's on with a disc in it to horizontal from vertical or vice-versa it will scratch your disc. If that is not the case then the spindle might not be seated right (the spindle is too low usually) which usually causes it to touch the laser. If you still have your warranty then send it back to microsoft. If you don't have a warranty then you can either pay them $100-150 to repair it or fix it yourself. If you want to fix it yourself then open it up, open the dvd-drive and on the bottom is a metal plate with 3 torx screws 1 black and 2 silver. More than likely the 2 silver screws need to tightened because the they adjust how your spindle is set. There are videos you can find on how to do this and how to open your xbox too. I hope this helps.
Jun 10, 2009 | Microsoft Xbox 360 Console
Disk Scratched By Xbox 360
Lazer burn!!!happens to a load of my discs too usually doesnt kill em though
Mar 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
