Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side I have to keep defrosting the freezer every 2 months or so the temperature starts going up the fridge runs more often when we remove the back panel within the freezer it is built up with ice to get the freezer back to running right and the correct temperature we have to defrost. Is this the temperature sensor gone?
  • GE Master
  • 1,606 Answers
Do this when the refrig starts to warm up . Don't defrost before this test .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jul 18, 2010
GE Side-by-side refrigerator defrost drain trough keeps freezing up. Drain tube is clear and never gets frozen but ice builds ups and overflows into the bottom of the freezer. What is causing this?
Sounds as if the defrosting timer or the heating element has gone out. Since the fridge works without problem off and on I would lean toward the heating element.
Mar 26, 2016 | GE Refrigerators
Temperature rising in freezer and fridge motor running constantly
The temperature in the freezer will rise if there is no air circulation. Air circulation stops when the evaporator freezes solid. When this happens the thermostat cn not respond and the fridge keeps running.
Defrost the freezer and see if things return to normal. If they do then you have an auto defrost problem.
A technician can help you with this problem
Apr 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE side by side keeps frosting up and fridge is not very cold
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Jul 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Temperature in GE fridge went up to 85(!!) while set for 34.
The defrost is not working properly...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | Kenmore 73503 Stainless Steel Bottom...
Fridge broken, freezer is temp. that fridge should
heatman101
Jun 26, 2010 | GE GSS20IEP Side by Side Refrigerator
GE Side-by-Side model #GSSWGPDWW freezer stopped working.... help
First of all , a GE , GSS model has no defrost timer , or calrod heater . If your ready for a little work , diagnosing , here we go .
You have a defrost problem , so , pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it .
Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR55X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and when to cycle off due to set temperature reached .
Dec 11, 2009 | GE (GTS16BCS) Top Freezer Refrigerator
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
374 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
