Question about Toshiba Televison & Video
Toshiba SD-560SR dvd player tray won't open, and it reads bad disk. What can I do?
5 Suggested Answers
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
  • 3422 Answers
SOURCE: Toshiba DVD player says every DVD is a bad disk
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Posted on Feb 10, 2009
SOURCE: Toshiba SD-480EKB DVD player
HD is not HDMI. An HD disc needs an HD DVD player.
Posted on Mar 27, 2009
Tray won open
Mine did the same once and when i opened the top cover i saw 2 disks jammed inside. Try it and see. Hope it helps
Aug 18, 2013 | Toshiba SD-V392 DVD Player/VCR
My sd-k770 loads a dvd and then opens the tray backup without ever playing. Basically doesn't seem to want to keep the loading tray shut.
Most likely the laser pickup needs cleaning. It is not seeing the disk. If cleaning does not help, the pickup itself is probably bad. These are usually not feasible to repair as the pickups cost as much or more than the whole unit. Thanks
Oct 29, 2009 | Toshiba SD-K770 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Won't open
Most of the times, the belt that drives the disk tray became too loose.
Solution: replace the belt. You can try to clean the belt with something like alcohol or isopropanol but then the problem returns sooner or later.
Jul 09, 2009 | Toshiba SD-3990 DVD Player
Region code unlock toshiba sd 4100
1. Power on the player.
2. Open the disk tray.
3. With the remote, enter the numbers 9 8 7 9 and
then press 0 (for region 0, or multiregion). A prompt
at the upper right hand corner of the start screen should tell you that the player has been set to region 0.
4. Close the disk tray.
5. Power off the player and then power it back on.
Jul 07, 2008 | Toshiba Televison & Video
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
Trouble with the disk tray
clean the tray, or replace the belt open the cover of your dvd
Jan 19, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
