Posted on Jul 18, 2010
I'm trying to load drivers for hp 1012 printer and get 3/4 way through and get this error message The data is invalid. I have windows xp and downloaded the most recent drivers from hp
Need a printer driver for a hp 1012 laserjet printer for Windows 7 professional
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Unfortunately my database doesn't an HP driver for the 1012, I use a 1018 and have chosen to stick with XP Pro.
I suggest that you click on the following link and hook up to the largest FREE database on the Internet: Free Driver Downloads
All the best
Ben
I have a HP Laserjet 1012 desktop printer. Are there any windows XP 64 drivers that will allow this printer to work with a XP 64 system?
Welcome to FixYa!
HP Laserjet 1012 does not have a driver for XP 64bit.
HP also does not have driver for Windows 7 32bit and 64bit with this particular printer.
They are urging their consumers to upgrade the printer(s) to a compatible operating system.
TIP: If you are going to install this printer to a Windows 7 operating system, try to using the Vista drivers and install it using the compatibility mode feature of Windows 7.
Thank you for using FixYa!
Keep me posted.
Jas247
2answers
I have W-XP and HP LaserJet 1012. I've lost the
Have you tried getting a copy of the drivers from the HP wbsite and also check in add remove programs and remove any of the hp software for that printer before you try new drivers.
27helpful
3answers
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
Cheers,
T
1helpful
4answers
I cant install my lexmark x4270
Hit Start, Run and type Regedit
Find the following HKEY_CURRENT_USER\Software\Microsoft\Windows| CurrentVersion\ Explorer\User Shell Folders
In the right pane - see if these is any entries which has an F or any other alphabelts not C (your OS folder) modify data to C:\
Has worked for me on the same error message
1helpful
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Unsupported personality: PCL on leopard
uninstall and reinstall the printer drivers
k24674
Grand Canyon Tech
Grand Canyon Tech
