Question about Brother HL 5170DN Laser Printer
Brother 5170DN Replaced the drum, but lite is still blinking, what do i need to do?
  • mkearney Jun 23, 2008
    baught new cartilage, drum still blinking.....and no printing
    Problem Solver:
  • 14 Answers
Normally there is a drum reset procedure with every new drum.
To reset your drum counter open the front cover (as you would replace the drum)
leave the cover open and the printer on.
Press the go button untill all 4 leds are lit. After that release the go button.
Normally now the drum counter has been reset, you may close the front cover again.
To check your drum status, press 3 times go in a fairly fast way. By doing that the printer will print his configuration pages, on the second or third page i guess you will find your pagecounters and the remaining life of your consumables.
Check the status of your drum, it should be full again.
Posted on Dec 06, 2008
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
Tip
Brother HL 5170DN Printer Toner error
Trick Brother HL 5170DN printer into think there is toner left. Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
on Feb 01, 2010 | Brother HL 5170DN Laser Printer
I replaced the fuser in a Brother HL5170-when I turn it on, all 4 lights are blinking. What might be the problem?
This is what's called a Service Call, meaning the machine has experienced a problem that it doesn't think an end-user can support.
According to the manual:
"Push the Go switch and the Job Cancel switch at the same time during the service call and hold them. And then push the 2 key additionally to show the service call type by LED combination."
Which I'm assuming means press and hold the two buttons, then press them both again.
The combination of the LEDs tells you where the problem is:
RED Status +:
Toner LED = Fuser (Fixing Unit)
Drum LED = Laser
Paper LED = Main Motor
YELLOW Status +:
Toner LED = Main PCB
Drum LED = Engine PCB
Paper LED = DIMM
All of which are expensive parts and also expensive repair.
Oct 12, 2010 | Brother HL 5170DN Laser Printer
Brother HL-5170DN 4 yellow lights - seems dead
if all the lights are flashing it means there is a physical problem with one of the main parts of the machine, such as the power supply or main board. you can find a technician on their website who would be able to fix it for you
Mar 23, 2010 | Brother HL 5170DN Laser Printer
My HL-2140 brother laser printer is flashing a red error
1>If the toner lite is blinking , it's mean the toner life near to end. In these case please replace the toner cartridge.
2>f the drum lite is blinking , it's mean the drum life near to end. In these case please replace the drum.
I hope it will help to solve your printer problem.
Feb 09, 2010 | Brother HL 2140 Laser Printer
I bought the printer in early 2006. After the initial cartridge ran out, I went through 2 TN-570 cartridges. After that my problems started. I put in a new authentic TN-570 cartridge and got heavy...
If you are still ghosting after replacing the drum (especially multiple times), it shounds like you need to have the high-voltage power supply PCB (HVPS PCB) MSRP is $43.38
No matter how little or how much you print, mostly depending on the type of paper used and the environment, this part can go out.
Jan 31, 2010 | Brother HL 5170DN Laser Printer
I have brother 5170dn printer but printer all light continuous blinking
it is about fuser unit. Or it needs reset ,if that could not help, then you need new one. Hope it helps
Oct 29, 2009 | Brother HL 5170DN Laser Printer
Brother hl 5170dn light amber
Open the printer - remove the toner etc. shut the door. Should resolve the problem.
Jun 18, 2009 | Brother HL 5170DN Laser Printer
HL 5170DN - the red service lite stays on and the orange paper lite is flashing; printer does not initialize
Since when this problem arised, have you install a new cartridge?
Try to unplug the USB connection.
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Let me know the further status so I can investigate further and fix the problem.
Oct 06, 2008 | Brother Office Equipment & Supplies
Brother hl-1430 :drum , ready and alarm leds flashing
This just means that your drum life has nearly reached his end.
Note that when you replace the drum you need to perform the drum counter reset procedure, otherwise the leds will keep on burning after replacing the drum unit.
Apr 03, 2008 | Brother HL 5170DN Laser Printer
Brother HL 5170DN Laser Printer Logo
1,236 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
