Question about LG 24" Built-In Dishwasher - Black
Displays LE and will not wash dishes
My dishwasher started this a couple of days ago and I need help!!! Thanks!!
    Novelist:
  • 112 Answers
LE is a motor error.
Possible Causes: Wiring connections, Impeller is locked, Rotor is locked, and or the Blade is locked.
Remedy: Repair the wiring issue, Remove the item stopping the turning of the motor/rotor/blade, Replace the sump assembly, or Replace the main Power Control Board.
If your motor was making in knocking sound before this error, then your issue is probably the motor sump assembly. Just replace the sump assembly and your problem is resolved. You can get these from EBAY for about $105 with free shipping.
Good luck.
Posted on Jul 24, 2010
Dishwasher is a whirlpool DU940QWDB3. When yu press button to start washing, lights go on but nothing happens. Where should i start trouble shooting this? Thanks
Dear Sir:
see the wiring diagram attached.
1) I recommend the switch door, if are open the machine will not close the starting relais as you will see in the diagram.
sincerely. God bless you.
May 07, 2012 | Whirlpool Dishwashers
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Error "LE" on the display after initial water load
just perform the tub cleaning operation as advised. nothing else. getting soiled
Mar 18, 2010 | Washing Machines
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Hi, We have a small CDI454-80 Candy Dishwasher. It is just 18 months old and has only been used around twenty to thirty times. It has recently started to leave a film on all the dishes after the wash is...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Dec 07, 2009 | Candy A8001 Dishwasher
LG DISHWASHER, STOPS WORKING AND DISPLAYS LE. WHAT DOES THIS MEAN
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Oct 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
LG 24" Built-In Dishwasher - Black Logo
127 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
