Every time I turn my phone on it goes to the camera screen and won't change. If I press buttons there is no response. If some one calls I can answer but then it drops the call. Is there anything I can do?
I have the same problem - went to t-mobile and they won't fix or replace - offered no solution other than to buy a new phoneI have the same problem - went to t-mobile and they won't fix or replace - offered no solution other than to buy a new phone
You can't post conmments that contain an email address.
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Hi Try hard resetting it.This procedure may erase all changes effected on the i phone Press and hold the power button and the menu button.Wait until the apple logo appears.
1. Power off phone. If it won’t turn off, take the battery out.
2. Press and hold the Power and Camera
button at the same time. Release the Camera button
when prompted.
3. Press Volume Down key.
4. A yellow triangle will appear. Press on the screen just above the
back key.
5. Select option wipedata/factory reset (Alt + W).
The Backflip will then complete the hard reset.
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode.
When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
