Question about Panasonic BL-C30A Network Camera
Hi, i find a problem to set up for access viewnetcam registration, the message was said: Failed to access test from the Internet.
  • 6,487 Answers
Base from the description of your problem its telling us that something is blocking your camera to connect to the internet, this can be due to your routers configuration to correct this one open the port that your camera is using on your router so it can be access to the internet and register with that service. You access the router setup page and look for port forwarding then open the port number that the camera is using.
Posted on Jul 18, 2010
My n70 says simcard registration failed i do check imei and validity all fine and some time if gain network u can call send message even access to internet
i think you are having a problem with the network ic of your n70. take your phone to some harware experts or in some cases reinstalling the firm ware also has a good chance of winning
Aug 30, 2011 | Nokia N70 Cellular Phone
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
I have successfully setup complete with netcam model BL-111 and BL-131, the system given me internet access is http://koswemin.viewnetcam.com. But I can not log in. The search engine said can't find....
ok i have tried to connect to it . yes its says it cant be found . try recreating the link using a diffrnt name .example > (koswemin1.viewnetcam.com) also make sure that you are spelling everything the same way as when you created the account.. if anything is diffrent it will say can not be found.
Nov 13, 2009 | Panasonic BL-C131 Network Camera
Hey i cant access the internet on my samsung pixon or receive picture messages . internet comes upo with connecting failed . picture messages reteiving failed define network settings
Same... I can't access it. Maybe it depends on your location or what sim you are using. Some sim cards don't allow access to the internet while others allow free acccess.
Jul 21, 2009 | Samsung Cell Phones
Simcard register problem
you are on orange network if it says that and you must conatct your provider and get wap settings and url for registration on sim on the phone
Apr 02, 2008 | Nokia N73 Cellular Phone
Cannot register 2nd BLC30a with viewnetcam.com
RECEIVED THE FOLLOWING INFO FROM A PANASONIC REP IN TORONTO PERTAINING TO SETTING UP A SECOND CAMERA:
"THE FIRST CAMERA MUST NOT BE AT ADDRESS XXXX.XXXX.XXXX.253 (EXAMPLE 192.168.1.253). DO ONE OF THE FOLLOWING BEFORE SETTING UP THE SECOND CAMERA:
1. CHANGE THE IP ADDRESS OF THE FIRST CAMERA THROUGH STATIC SETUP (EXAMPLE 192.168.1.252)
2. DISCONNECT THE FIRST CAMERA FROM THE NETWORK PRIOR TO SETTING UP THE SECOND CAMERA. (THE FIRST CAMERA WILL GRAB A NEW ADDRESS THROUGH DHCP THE NEXT TIME IT IS CONNECTED).
THE REASON FOR DOING ONE OF THE ABOVE IS THAT THE FIRST CAMERA IS PROBABLY STILL AT AN IP ADDRESS ENDING IN 253. A NEW OR FACTORY RESET CAMERA WILL WANT TO GRAB THE SAME ADDRESS AND CAUSE AN IP CONFLICT ON YOUR NETWORK.
HOPE THIS HELPS YOU.
WARMDF
Feb 09, 2008 | Panasonic BL-C30A Network Camera
Problems in connecting to my blc30a through the website viewnetcam.com
Are you trying to access the camera in the local network? Have you assigned a static ip address to the camera? Which router are we using?
Feb 27, 2007 | Panasonic BL-C30A Network Camera
Unable to access camera through the Internet
Which port did you open? I found that my isp was blocking both 80 and 8080. Eventually I was able to access the camera with another port. But when you use a non standard port you have to specify this after the url.
Sep 21, 2006 | Panasonic BL-C30A Network Camera
Panasonic BL-C30A Network Camera Logo
273 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
