Question about Kenmore Dishwashers
Why won't my dishwasher drain? - Kenmore Dishwashers
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherwhy won't my dishwasher drain - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 18, 2010
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain
the drain hose clogged, fix the clogged.
Jan 28, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
Most likely the exhaust selenoid is burned out - or the small metal arm that connect to exhaust valve is disconnectrd
Jan 05, 2012 | Frigidaire Dishwashers
Hotpoint fdw65 won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 12, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
Water won t drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 10, 2011 | Frigidaire Professional Series 24 in....
Dishwashers Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
