Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
Clicking noise from board on regular interval. Noise coming from large relay. Lights dim everytime relay clicks.
  • GE Master
  • 43,501 Answers
Compressor is tring to start... check out these tips...
As the weather is getting warmer for many people their freezerclicking noise from board - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 20, 2010
I've installed a new bulb on my BMW 330i & it still won't work. What could be the problem? Also, there a clicking noise when I brighten or dim the lights.
thers a relsy thats works ur lights as they are high power replace relay this the clicking noise u here u will probly ind bulb was ok
Sep 27, 2013 | 330i Bulb
Single chinking noise
Have the charging system voltage checked, that could be relays clicking from low voltage.
Nov 01, 2017 | Cars & Trucks
There is a clicking noise coming from under the dash board of my 2001 Nissan Altima. Its more toward the fuse box. The lights go dim as I'm driving it and the power seat will not work now. Any suggestions?
Sounds like the seat motor has a short. Unplug the connector wires to the seat if you can reach them. The clicking is probably a relay (circuit breaker) for the seat and is resetting. You might also unplug the relay.
Mar 18, 2011 | Nissan Altima Cars & Trucks
There is a clicking noise coming from the area around the underhood fusebox on my 2006 pontiac grand prix when I try to start the car. The goes in 20 - 30 second intervals.
SOUND LIKE BAD RELAY CHECK HEAD LIGHTS TO SEE HOW THEY FUNCTION ARE THEY BLINKING OFF AND ON.MOST TIME THE DRL RELAY WILL GO BAD YOU GET CLICKING NOISE.IF LIGHTS OKAY CRANK CAR UP.LET CAR IDLE FEW MINUTES TO SEE IF IT IDLE DONT STALL OUT. COULD BE FUEL PUMP RELAY.
Jun 14, 2010 | 2006 Pontiac Grand Prix
Door mounted ice dispenser does not work, lights dim when pushed cyclic "clicking" noise coming from back of unit which causes the lights inside as well as those plugged into same circuit to dim when it...
the clicking noise is your water valve operating, or not
if its causing the light to dim, your loosing ground
somewhere in the circuit.
juding by your diagnososis i would have to think your selector board on the freezer door is bad..
probaly a your shorted somewhere in the logic board
and thats why your loosing gorund
Oct 12, 2009 | Hotpoint HSS25GFP Side by Side...
Everytime i attempted to start it there is a clicking noise coming from the connector under the seat. it has two fuses on the left and right of this connector. Will i have to replace the whole wiring??
if he engine is not turning over but there is a clicking, that is a flat battery, the noise is the solenoid going mad, stop doing it and charge up the battery or you'll burn it out. if the battery is good (do the lights dim when you put the brake on? quick test) then you may have bigger problems, maybe tthe starter motor. the clicking could also be a relay, a small plastic box.
Aug 16, 2009 | 2002 Yamaha Road Star Warrior
PDS22SBSALSS Clicking Noise/ Temperature Control Panel
Your start relay and condenser are defective, it would appear. They are there to 'kick' the compressor into starting. They should then click off and reduce the power sent to the compressor. When they don't, you get the dimming lights. See your local library for any service information they may have on the shelf. Your issue should not be model specific. About the control panel, cycle the connectors. You may catch the problem.
Jan 23, 2008 | GE Energy Star PDS22SIS Stainless Steel...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
