Question about Sony Playstation 3 (PS3) Console
My playstation 3 has been working just fine. It notified me to perform an upgrade, and I upgraded the system software. Since then, however, I cannot access anything but the system software upgrade page. Only the zero (Cancel) button works and it will not allow me to cancel the upgrade or use any other function from either a remote universal controllor or from the handheld wireless controller. I have rebooted multiple times, but the same problem. Obviously the upgrade has corrupted something. Help. Thanks, Tom Bashore
  • Codebluedevi Jul 18, 2010
    I am still trying to see if there is a simple way to restore my PS3 to where it was before an update was performed. I have tried the above with no success. Any other thoughts?
    Thanks,
    Tom Bashore
  • Sony Master
  • 11,800 Answers
The upgrade process wasn't allowed to finish, probably the connection went down during it. But you might have just stumbled on the dreaded 3.21 firmware update and everything was messed up.
Nothing more you can do, unfortunately the console will have to be sent to a dealer to be reflashed, something that requires specialized equipment.
Posted on Jul 18, 2010
  • 4 more comments
    I had another thought. It would be cheaper to buy a new hard drive and install fresh than to get this repaired. If I replaced the hard drive (seems easy enough to do) and then downloaded the upgrade software from Sony, would that work to get the system back up and running?
    Tom
    Any thoughts about just replaing the hard drive? Can get on for $30 on ebay.
    Tom
  • Azrael SRL Jul 19, 2010
    That upgrade was for the firmware, which is installed in the equivalent of the BIOS, not  some other software/game update that would be installed in the hard disk. Changing it will not have any effect.
    If you want to make a last effort you can try to reflash the firmware yourself following this
    http://us.playstation.com/support/system...
    but for this to work you must be able to navigate to the update folder on the stick , which you can't.
    As i said your PS3 must have the firmware reflashed by a dealer, using special equipment.
  • Codebluedevi Jul 19, 2010
    What a pain!! I had no issues prior to the update installation. Seems like Sony should take care of this, but I can't figure out how to get to them through their website.
    Thanks for the advice.
    Tom
    You can't get them to their site because all hardware fault are addressed simply by sending the console to them to be repaired. Unfortunately firmware update errors aren't considered as covered by the warranty, so you will gonna have to pay for it. Don't send the console by mail, go yourself to the dealer and make noise, you might get a smaller bill, it's their fault afterall if the update hasn't worked as it should.
    Unfortunately both the dealer and Sony site want $120 as a base to repair this. It is not the money as much as the lousy service. This is the second time I have had trouble with Sony products and their service. I only use the playstation for the blu-ray player anyway, so it is just simpler to buy a new blu-ray player (and not that much more expensive). Guaranteed it will not be Sony.
  • Sony Master
  • 6,993 Answers
surely, the upgrade has corrupted the hard drive. The solution I'm going to give you now will involve a complete/full system restore. Follows the steps and you shouldn't have any problem:
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADD ONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I wish you good luck.
  • 2 more comments
    Did not work. I was able to reboot as you suggested and the system went through the various 'beeps" fine, but the first screen that comes up is not a reminder screen, but rather the systems update screen again with its instructions that you will not be able to use with Linux, etc. The system had already gone through this update process. Again the only control I have is with the zero and I can't cancel the update
    Any other way to get to safe mode? Do I need to somehow reload system software from scratch? Any other way to get to a system restore?
    Still struggling.
    Thanks,
    Tom
  • Walesarumi
    Walesarumi Jul 18, 2010
    unfortunately, there is no other way to enter into safe mode apart from the way I gave to you. You can check this play station forum and you will discover that its the same: http://boardsus.playstation.com/t5/PlayS...
    Secondly, yes, you need to reload the system system software from the scratch because its actually a software problem.
    The steps below directs on how to perform system restore. Its from play station forum and I don't think its different from the one I gave you earlier but you can try it. And if you are still having the problem, after all these solutions, then I would suggest you call Sony via the phone and they should be able to direct you on what to do next since they
    1. Turn off Playstation®3.
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
    4. When you hear the 2 beeps take finger off power button.
    5. You will be prompted to plug in your controller via USB and then hit the PS button
    6. The Recovery menu will pop up.
    The current Recovery Menu supports:
    • Restart System: Restarts the PLAYSTATION®3 System.
    • Restore Default Settings: Reset all system settings back to default.
    • Restore File System: Checks for corrupt/missing system files.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
    • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    • System Update: Update the PLAYSTATION®3 System
    Take care.
    Still waiting to hear back. Any other way to restore prior software or to reboot in safe mode?
    Thanks,
    Tom
  • Walesarumi
    I just sent a comment, read it.
Does not play youtoob videos
Youtube changed its file system from videos being in .flv format to .mp4, you'll have to wait for Sony to make the next move on restoring the PS3's ability to watch online video.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
Wont play a blu-ray movie the playstation! needs "encryption key?
Yes it does have wireless internet. Go to the beginning of the cross bar menu, where system update is. and scroll down, you will see network options.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Just got the new moon dvd in blue ray and the play station is telling me that i need to renew the encryption key and to perform a system software update to renew the encryption key. I dont have a clue can...
To perform the update you require a active internet connection or you might just take the unit to the store for this update which I consider better.
Good luck.
Mar 20, 2010 | Sony Playstation 3 (PS3) Console
PS3 no longer reads discs after 2.80 system upgrade
Send it to best buy and they will fix it for you thats what I did with mine
Hope it helps
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
It says"Perform a system software update to renew the encryption key"?My ps3 wont play blue ray dvd?
your PS3 software needs to be updated in order to play blu-ray.
Its explained on this page:
http://manuals.playstation.net/document/en/ps3/2_60/video/aacs.html
On that page click on the link that says "update the system software".
On the next page it will explain to you the different ways to upgrade the software on your ps3.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 does not want to play blue ray dvd?
You'll have to update the system software for your PS3 for it to play blu-ray movies.
You can read about it here:
On that page click on where it says "update the system software" and then on the next page it will explain the different ways you can upgrade the software.
Ps3 40 GB upgraded to 160 GB but it won't work
yes very common problem with this harddrive..you must upgrade to a 60gbSATA
Sep 17, 2008 | Sony PlayStation 3 40GB System
Playstation 3 upgrades
sony has released some upgrades and others are to follow. to see if your system can be upgraded go to...
us.playstation.com/support/ps3
in the center find the listing backward compatability on ps3
on the next page you will find if your system can be upgraded
good luck
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
you need to upgrade your software this can be done by using a storage media disc,using the internet connection if you have one or inserting a new game which might make the ps3 upgrade it self
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
