Vertical lines on print outs - Office Equipment & Supplies
  • 3 more comments
  • Anonymous May 20, 2008
    vertical lines on print outs
  • Anonymous Jun 11, 2008
    printing posters shows it mor but there is a darker line across my print every pass it does an overlap and makes a singel line show a bit darker?
  • tanveer_lhr Aug 11, 2008
    I have Horizontal black lines on print, please repply me on
  • daftks Nov 26, 2008
    i have the same problem but only half of a page.
    the colours are faded and the vertical lines are seen on that side
  • Matthew Roma Dec 11, 2008
    I have a repeating wide smudgy horizintal line across my printed pages, 7 stripes to a page.
    I've tried making 30 or so copies hoping it would fade from use, correcting itself, but there was no improvement at all.
    Teh stripe is thicker in the middle, and tapered at the ends. It looks something like this:
My lexmark e330 printer,their is three vertical lines on the printouts on same lenth what is the earror?
Posted on Oct 06, 2011
Copier is not connected to PC. Stand alone. Vertical line on copy
To determine if the line is caused by the cartridge, try printing a test page. Not sure of your model, but there should be a menu setting to print a configuration page. If that configuration page prints out clean, then there is likely debris in the scanning area of the document feeder. You should be able to locate the debris by lining up the vertical line with your feeder. If you could reply back with the model of your Canon device, we can help you a bit more. Alternatively, you should be able to pull the cleaning instructions from the manual for your copier.
Dec 27, 2015 | Canon Office Equipment & Supplies
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Vertical lines out of alignment
Print a test print and then go through the setup procedure to realign the printed test pattern. This should restore the vertical line printing to correct.
Sep 20, 2009 | Office Equipment & Supplies
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
I have the same problem vertical line epsonr230
get your printer service and get new INK jets mean Cartage for your printer thank you it will get no vertical lines then .. it is caused when cartages are leaking..
Jun 25, 2009 | Epson STYLUS R230 InkJet Photo Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
1,697 people viewed this question
