Question about Haier HSL06WNAWW Compact Refrigerator
Light is on, can hear a click coming from motor area but i don't here it running
  • Haier Master
  • 43,501 Answers
Compressor is tring to start... check out these tips...
As the weather is getting warmer for many people their freezerlight is on, can hear a click coming from motor - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 20, 2010
Why won't my car start? What is making the clicking noises coming from the engine compartment?
soleniod on the starter motor is the most likely source of the clicking noise. The starter motor may be faulty and not cranking over the motor.
https://www.youtube.com/watch?v=tzc9WApF7Io
Aug 15, 2015 | 2001 Oldsmobile Aurora
1996 ford transfer motor will not work. 4x4 switch light will not come on. don,t know if switch or motor. please help. have checked fuses.
You should have a relay in the circuit. Unplug the harness from the transfer motor and then see if you can hear the relay click when you flip the switch. You also can check voltage to the motor with a volt meter. If you are not familiar with this, you should have a qualified mechanic check it. If you have voltage to the motor, then the motor is more than likely bad. If not could just be the relay.
Nov 08, 2014 | Ford Cars & Trucks
Power not coming on
Power does not come on for the following reason, THE POWER SUPPLY is bad. Unplug the power cord, then press and hold the power button for 30 seconds. Then plug it back in and hit the power button. If you see no lights, hear no fans running, don't hear the disk drive running, don't hear the cd drive click once and don't see the light on the cd drive come on for a second or two while it clicks, then you are getting no power and need to replace the power supply.
Mar 19, 2012 | E-Machines eMachines Desktop PC
The craftsman model 137-248880 table saw won't power up. The breaker popped. I waited for it to cool, blew out all the dust from the motor and it still won't power up. The blade turns free so I...
Your electric motor probably has a flat spot ... give it a tap .. And try to power up.. I had that happen to a drill... I had to unplug it.. Uncover the motor and physically rotate the motor . Also the other problem area is the trigger (switch). May be worn.
Jan 11, 2018 | Garden
Freezer not freezing - can hear a clicking noise coming from areond the th.ermostat / motor area
My freezer has a light that says "high temp" but the freezer isn't freezing my products.....what can I do? It also says that the temp has been 23 degrees or higher for more than 1 hour. I really don't think that the problem is being in hot weather
Apr 22, 2011 | Freezers
Car wont start. Turn the key and only get mileage lights to come on and a clicking noise from under the glove box area. have a 5 speed.
it sounds like your starter relay is working (thats the clicking you hear) so the problem possibly lies withe starter motor or the solenoid mounted on top of it.
Nov 17, 2010 | 1998 BMW 3 Series
I have a NordicTrack Elite zi treadmill. While running I hear a ratcheting click coming from the front housing area. When I hear this ratcheting click the belt is slipping a little bit. Any ideas of...
This is more than likely a loose drive belt, which would explain the slipping as well as the sound. To tighten this take off the plastic cover that covers the motor. You will see where the motor connects to the front roller with the drive belt. To tighten it there are two bolts that hold the motor to the machine, loosen those then pull it tight and retighten them, This should eliminate the problem.
Aug 17, 2010 | Nordic Track NordicTrack Elite zi...
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Haier HSL06WNAWW Compact Refrigerator Logo
81 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
