Question about Microsoft Windows XP Home Edition
Windows folder open command
Whenever I doubleclick on a file folder, it always opens up in a new window. It is getting rather annoying to have to close all of these windows, and I don't know how to fix the problem. I have clicked on Options>Folder Options...> and then selected "Open each folder in the same window" with no difference. I have even clicked on file types>Folder/File Folders>Advanced, but there is no option to change, the only selectable options are "Find" and "Open". What should I do?
  • Matthew Haynie
    Matthew Haynie Apr 22, 2008
    The picture isn't there.
  • Matthew Haynie
    Matthew Haynie May 02, 2008
    Oh, don't worry, I've reinstalled and fixed many PCs before this and I know how to install an OS. Thanks for helping!
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
If you mess around in the registry, or install some different software packages that add things to the right-click menu, you can end up with this problem
There's a quick and easy fix for this problem. Open up regedit.exe by using Start\Run and then browse down to this registry key:
HKEY_CLASSES_ROOT\Directory\shell
Double-click on the default value and set it to "none" without the quotes, as seen here:
This will restore the normal behavior.
If you are getting a message that says "Windows cannot find 'PET32.exe'", then at some point you had a virus, or still have a virus. First, make sure that you run a virus scanner to get rid of the virus. Then run the regsvr32 command above, which should fix the problem
I hope this help.
Hands of Time
Posted on Apr 21, 2008
  • Pierre Wepener
    Pierre Wepener Apr 22, 2008
    All likeness this is due to a virus or worm, regardless wen OS start behaving like this your best and cleanest option is to re-format and re-install the OS. You can to this as follows: (But please if you can, take your computer to a vendor or Pro, before trying to attempt this on your own!)
    Reformat you hard drive and reinstall the Operating System. Insert you XP cd in the Disc Drive, reboot, F2 or Del to enter BIOS, choose first Boot Drive as CD\DVD ROM, F10 SAVE. Computer will Boot from CD\DvD - follow the on-screen instruction to delete and re0allocate partitions, the computer will format hereafter and setup will commence just after that. This is not 'job for a person new to this, you will lost all your data if you did not made back-ups prior to this process. Rather to you machine to Pro or Vendor that can help you with it.
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
How do I reset the password on the windows 7 home page
Windows has a built-in security system that requires a user to type in a password to get to his personal account.
Only an "Administrator" account holder can make software changes to the computer.
All other users, including Guest users, need the permission of an Administrator to make any system changes.
However, if you have a guest account and need to access the Administrator account to make changes, you can do so via the Command Prompt feature.
Log in to your Guest account in Windows.
Go to "Start" > "Search" and type in "windows/system32/cmd.exe" to find the Command Prompt feature.
When the file appears on the search menu, drag it to your desktop.
Leave the search window open.
Right-click the cmd.exe file on your desktop and choose "Rename."
Type "sethc.exe" for the new name and click on an empty area next to the file name to save the new name.
Right-click on the "sethc.exe" file and click on "Copy."
Go back to the open "windows/system32" folder and right-click anywhere in the folder.
Select "Paste" to put the "sethc.exe" file inside.
Choose "Yes" when asked if you want to overwrite the current file.
Go to "Start" > "Log Off." It will bring you back to the User Account menu.
Press the "Shift" key 5 times in a row.
The Command Prompt will open.
Type "net user administrator [password]" and insert a new password in the [password] section.
Press "Enter" to set your new password.
It will bring you back to the User Accounts menu.
Click on the Administrator User Account and type the password you just set to log in to the account.
Dec 22, 2011 | Compaq Computers & Internet
How can i open an .msu file? i just downloaded in
.MSU files are related to Windows udpate. To open files with .MSU, you should have Windows-Microsoft Windows Update Stand –alone Installer (Wusa exe).
Another program that uses file extension MSU is Blaise File which was developed by Statistics Netherlands.
Below are the list of programs that can open .MSU files:
ImgBurn.exe ImgBurn ImgBurn - The Ultimate Image Burner! LIGHTNING UK! Burn using ImgBurn Low uniextract.exe Universal Extractor UniExtract Files..., UniExtract Here, UniExtract to Subdir Medium wusa.exe Sistema operativo Microsoft® Windows® Programma di installazione Windows Update autonomo Microsoft Corporation open Low wusa.exe Besturingssysteem Microsoft® Windows® Zelfstandig installatieprogramma voor Windows Update Microsoft Corporation open Low wusa.exe Microsoft® Windows® Operating System Windows Update Standalone Installer Microsoft Corporation open High
Extract and View Contents of Microsoft Update Standalone Package (MSU):
  1. If you are extracting a hotfix package, follow these steps:
    1. Double-click the Hotfix.exe file.
    2. In the Microsoft Self-Extractor dialog box, click Continue.
    3. In the Select the folder where you want to unzip the files to box, type C:\MSUFolder, and then click OK.
    If you are not extracting a hotfix package, create a folder that is named C:\MSUFolder, and then save the MSU file to this folder.
  2. At a command prompt, type the following commands. Press ENTER after each command.
    c:cd c:\MSUFolder
    expand -F:* Saved_MSU_File_Name.msu c:\MSUFolder
    expand -F: Saved_MSU_File_Name.cab c:\MSUFolder
The C:\CABextract folder now contains subfolders. Examine the files in the subfolders to determine which files are updated by the MSU.
Dec 24, 2009 | Microsoft Computers & Internet
My mp3 & video files always converted into jpg files
I too had the same prob... But got rid of it with the help of help 2 design site.. Go through this..
A new malware virus MediaControl.exe found in some parts of central asia late this month.
It changes the extension of all the media files like AVI (.avi), Music (mp3, …) to .jpg.
This just canges the file extension. Not the file format.
To play the media file, you need to re-change the file extension to the previous type, or open the file using the media player.
Malware name is MediaControl.exe.
It internally creates a folder by name ”mcont” in AppData of OS drive. AutoRun inside mcont also puts the MediaControl.exe to the winwos start up of msconfig.
How To Remove MediaControl.exe?:
1. Kill the process MediaControl.exe is running.
How?:
Press Ctrl + Shift + Esc to open the windows taskmanager.
Click on the Processes tab
Search the MediaControl.exe, Click on End Process button at Bottom right.
2. Remove MediaControl link from Windows Start up
How?:
Click on Windows Start Button, and on the Run option at the right side of the window,
Type msconfig on the form opened at left bottom.
This will open the System Configuration Utility
Click on Start Up tab.
Search for MediaControl, Untick the link. Click Apply -> OK, Click on Exit Without Restart on the dialog opened.
3. Remove the AutoRun from Computer:
How?:
Option 1:
Using Command prompt inputs.
Type cmd, to open the command prompt window.
Type the following command lines one by one.
cd C:\Documents and Settings\All Users\Start Menu\Programs\Startup
attrib -s -h -r /S /D *
del *
y
cd C:\WINDOWS\system32\mcont\AutoRun
del *
y
exit
Option 2
Using Safemode booting.
Restart the Machine.
Click F8 on Booting, this wil open the machine in safe mode for you.
Browse for the folder
mcont
inside C:\Windows\System32\
Delete the folder mcont.
Restart the computer in the normal mode.
Thats All.
Once you remove the mallware, your computer is free of mallware but, you are left with thousands of your media files changed its exentsion to .jpg. It is not an easy job to change the file extension one by one. You can use an Auto-Renamer programs.
We recomond you the AndRenamer program. You can download it here: [ftp://ftp2.antp.be/antp/software/antrenamer2_install.exe]
Mar 30, 2009 | Microsoft Windows XP Professional SP2 for...
How to recover the windows server2003 (missing file c:\ windows\system32\config\system
Two options:
Either reinstall Windows
OR
Follow the procedure below
It will be better if you print these instructions since you will need to type many commands later. I'm typing a detailed procedure to recover your windows.
It's possible that somehow your Windows registry is corrupted. But there is a backup. Only thing is you need to manually restore it.
Boot using your Windows XP cd in the drive and press enter when it asks to boot from CD (if it does not ask, then you will need to go to the CMOS setup by pressing DEL or F2 key and change the boot sequence)
Now, when booting from 2003 CD, it asks if you want to do a recovery, press R and you will get this screen:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to quit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log onto
(To cancel, press ENTER)?
Type 1 and press enter.
Now type the commands I am putting below, one by one per line and press enter after every line.
md c:\tmp
cd system32\config
copy system c:\tmp\system.bak
copy software c:\tmp\software.bak
copy sam c:\tmp\sam.bak
copy security c:\tmp\security.bak
copy default c:\tmp\default.bak
del system software sam security default
Now, type these commands: (Take care to type the dot as it is)
copy c:\windows\repair\system .
copy c:\windows\repair\software .
copy c:\windows\repair\sam .
copy c:\windows\repair\security .
copy c:\windows\repair\default .
Now type exit and press enter and the system will reboot.
Remove the CD and boot normally in Windows .
If the PC boots in to windows, then do the following:
Start Windows Explorer.
On the Tools menu, click Folder options.
Click the View tab.
Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the "Hide protected operating system files (Recommended)" check box.
Click Yes when the dialog box is displayed that confirms that you want to display these files.
Double-click the drive where you installed Windows XP to get a list of the folders. It's important to click the correct drive.
Open the System Volume Information folder. This folder appears dimmed because it is set as a super-hidden folder.
This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RP x under this folder. These are restore points.
Open one of these folders to locate a Snapshot subfolder; the following path is an example of a folder path to the Snapshot folder:
C:System Volume Information_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}RP1Snapshot
From the Snapshot folder, copy the following files to the C:\tmp folder with the mouse:
_registry_user_.default
_registry_machine_security
_registry_machine_software
_registry_machine_system
_registry_machine_sam
Now, once again put your Windows 2003 CD in to your CD Drive and reboot using the CD. Again press R for the recovery console.
At the console, type these commands one by one per line and press enter after every command:
cd system32\config
del sam security software default system
copy c:\windows\tmp\_registry_machine_software system
copy c:\windows\tmp\_registry_machine_system system
copy c:\windows\tmp\_registry_machine_sam sam
copy c:\windows\tmp\_registry_machine_security security
copy c:\windows\tmp\_registry_user_.default default
Now type exit and remove the CD. Boot normally in Windows and you must be back to normal.
If in case, Windows doesn't boot even following this procedure, then you need to reinstall windows. BUT you can still try a repair install instead of a normal install since that will let your programs and settings remain as they are, intact.
Post back and I will reply with that procedure.
HTH,
Regards,
Deboo
Feb 14, 2009 | Microsoft Windows Server Standard 2003 for...
I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
Drive not open
maybe you have accidentally change something or what? especially to the setting or something you have downloaded software which is malicious maybe not right!
Oct 24, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
