Question about ASUS P7p55de Lx S1156 P55 Atx (90MIBC70G0EAY0KZ) Motherboard
After enable of express gate i get no post or bios
After I enable of express gate i get no post or bios even when i clear cmos i get no bios or video.
    Champion:
  • 253 Answers
Try to clear the cmos.Take the battery out for a minut.Than restart....hope this helps
Posted on Jul 18, 2010
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
I have a Gateway GT5082 computer, the Onboard Video no longer works and I have a PCI Express video card to put into this machine, the problem is, I can't get any video on the screen to go into the bios and...
try to clear our cmos, you can do that whit jumpers, or if you don't know .. pul out power cord from computer, remove silver battery for few seconds and put it back in.. then try..
Feb 25, 2011 | Gateway GT5082 PC Desktop
When i install my video card the screen is blank
Use onboard graphics and enter the BIOS/CMOS by pressing the delete key during boot.
Go through the options, some-where there, there should be an option to enable PCI-Express slot, PEG when one is inserted. This need to be set.
So onboard VGA is disabled unless PCI-E Graphics card/PEG is inserted.
damnor01
Jan 25, 2011 | PNY GeForce 6200, AGP Video Card
Tenho uma placa mae ibm 49p1599 mas nao esta entrando o windows xp erro na inicializacao
If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure: Before proceding, be sure to review the safety information.
  1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
  2. Unplug all power cords from electrical outlets, and remove the cover.
  3. Locate the Clear CMOS/Recovery jumper on the system board.
  4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
  6. Replace any adapters that were removed.
  7. Replace the cover.
  8. Reconnect the power cords for the computer and monitor to electrical outlets.
  9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
  10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
  11. Unplug the power cords from electrical outlets.
  12. Remove the cover.
  13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  14. Return the Clear CMOS/Recovery jumper to its original position.
  15. Replace any adapters that were removed.
  16. Replace the cover and reconnect any cables that were disconnected.
  17. Turn on the computer to restart the operating system.
  18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
Nov 30, 2010 | IBM NetVista PC Desktop
Bios issue
Even if you turn off the on board graphics, the computer usually will output video until after BIOS post. Simply plug the monitor back into the motherboard video card. If that doesnt work you can actually just reset the cmos by opening the case ( make sure its unplugged) and there is a spot on the lower left where a jumper is and you can remove that to clear the CMOS. There are many you tube videos on how to do this. By doing this you will reset the CMOS to factory.
Mar 16, 2010 | Gateway GM5260 PC Desktop
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
Mar 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
P5NT won't boot
Have you tried clearing the CMOS by removing the battery with PSU off and then shorting the 'reset cmos" (or similar) pins on mobo?
Also found this on the ASUS web site under the specs for the P5NT WS board...
01.gif ASUS CrashFree BIOS 2
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support DVD. Users can reboot their system through the support DVD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Have you tried this?
Jul 26, 2008 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
It has no video after installing the card
When you see the blue dell logo, Press F2 to get into the BIOS settings.
When in the BIOS Settings. Enable PCI Express instead of PCI express.
Make sure the videocard is seated all the way in the slot as well.
Jul 23, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
ASUS P7p55de Lx S1156 P55 Atx (90MIBC70G0EAY0KZ) Motherboard Logo
149 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
