Question about Refrigerators
Our Belling Fridge Freezer appears good with the light on but only the freezer section appears cold. the temp display show H for the Fridge and -18 for the freezer. What is the best way to check if this is caused by a failed part?
    President:
  • 2,468 Answers
Check for frost on the rear wall of the freezer,if so remove this panel,the evaporator coil is here,if its covered with ice use a hand held hair dryer to defrost it and then check the defrost heater under the coil for continuity,they go open(bad) if its o.k. then suspect the defrost control be it timer or adaptive board
Posted on Jul 18, 2010
Why is freezer way too cold and fridge too warm when the temp display actually states the preferred temp?
Check the fan in the freezer section, its probably not working or turning too slow. Also check the fresh food cold adjustment its really just a door that gets adjusted, but it could be blocked with food, stuck or broken.
Sep 01, 2014 | Refrigerators
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Belling Bi60 Integrated fridge freezer (fridge) not working
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Dec 15, 2008 | Refrigerators
Belling B160 Fridge is warm Freezer is cold
In fridge freezer where the fridge is under the freezer, the cold air falls down a channel from the freezer. I had a similar problem and it was a failed defrost thermostat. The evaporator in the back of the freezer was a solid lump of ice and wasn't allowing any cold air to drop into the fridge. The defrost thermostat was changed and then 30 minutes with a heat gun melted the ice. It was worked fine ever since. On a side by side fridge, there is a bypass from the freezer to the fridge. Either way, you need an engineer. You are not the only one to see this problem with that model. I see two in Google.
http://www.ukwhitegoods.co.uk/forumsphpbb3/belling-b160-fridge-freezer-t48629.html
Sep 19, 2017 | Refrigerators
Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Sep 12, 2008 | Samsung Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
