Question about Coby DVD-224 DVD Player
My coby dvd-224 disc tray will not open. Any suggestions
    Genius:
  • Coby Master
  • 1,550 Answers
Disasemble and replace the belts of the charge motor
Posted on Jul 18, 2010
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Dvd player door does not open
Check to see if anythig is blocking the tray from opening. Also the tray motor or connections may be failing. I would open the case, remove and replace as many connections, one at a time, to make sure the connections were good. If the tray still does not move, then one or more than one component has failed. It could be an electronic component or the motor.
May 30, 2009 | Coby DVD-224 DVD Player
Coby DVD-R1000
Try this, it is the only known hack for Coby R1000:
Coby DVD-R1000
  1. Turn on the player (without a disc inserted)
  2. Press STOP 2 x
  3. Press SUBTITLE 5x
  4. Press the button for the desired RC (0=codefree)
Let me know if it works.
Sep 10, 2008 | Coby DVD-224 DVD Player
Coby 224 Screen Slowly Fades to Dark and Back To Light
Usually if your getting it with the MENU then your connection is weak, are you going through a VCR or some other type of device besides directly to the tv? Try hooking unit directly to the tv. Besides that, its possible you could of messed with the settings, go to the menu, go to advanced and do a reset to make sure no settings were adjusted, the disk has to be out of the tray while you do the reset.
Jul 14, 2008 | Coby DVD-224 DVD Player
Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Jul 06, 2008 | Coby DVD-224 DVD Player
Coby-224 DVD
Reset back to default
make sure no disc is in the tray
press right on the remote 3 times
down arrow once time- right 3 times - down arrow once then press setup the enter.
Jan 15, 2008 | Coby DVD-224 DVD Player
No disc message on my coby 224 dvd player
Thanks for using FixYa.
If the unit is showing "no disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Nov 27, 2007 | Coby DVD-224 DVD Player
Devise reads no disc when disc is inserted
there is a flat white strip that is connected to the body of the lens replace it if that does not remedy the problem replace the lens.good luck
Apr 17, 2007 | Coby DVD-224 DVD Player
Coby DVD-224 DVD Player Logo
139 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
