Question about Craftsman 4 Cycle Blower/Vac
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
  • 10,865 Answers
The mix of 2 cycle oil to unleaded gasoline is 40:1. Use craftsman 2 cycle oil if u can. Here is the owner manual. Enjoy. http://www.managemylife.com/mmh/owner_manuals/23690/MTD-Blower,-Gas-L0707143?brand_name_search=41AS320G799+MTD
Posted on Jul 18, 2010
  • 760 Answers
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Craftsman 32cc/170 mph leaf blower. Why does it die after a few minutes running?
Is this a consistent situation? Starts, runs then dies after a little while?
If so, sounds like carburetor/fuel pump (which is a one way diagraphm) issue.
Take carburetor apart, and also obtain a rebuild kit for it. Clean it well, compressed air through all the jets, replace the parts from the kit and reassemble. Re-install back onto unit.
Also... Replace Spark Plug, fuel filter and clean the spark Arrestor screen at muffler.
May 26, 2015 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
Was given a craftsman 32cc weedwacker. no manual. need to know what fuel it takes.
The website just says gas/oil (http://community.craftsman.com/Craftsman-Convertible-32cc-Gas-Line-Trimmer-reviews?tab=details). I'm not sure what that means. But on the Craftsman Community web page (http://community.craftsman.com/community) there is a link that says Feedback and Support. If you click that and fill out the form, someone should get back to you.
Hope this helps!
Jun 17, 2011 | Computers & Internet
I have a Craftsman model 358.797920 32cc blower want to know the mixture of gas per twocycle oil?
Most of these mix at 50 to 1. 500ml of oil to 5 gallons of gasoline should do it. If you don't feel comfortable with this mixture try 40 to 1.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
The cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Nov 16, 2009 | Craftsman Garden
I need a manual for a SEARS Best Blower/Vac Mulcher 32cc 170MPH 360CFM Model # 358.798980
manual:
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0710663.pdf
parts look up:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358.798980
Oct 31, 2009 | Craftsman Garden
Craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Jun 10, 2009 | Craftsman 4 Cycle Blower/Vac
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman 4 Cycle Blower/Vac Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
